MADVIBES Posted May 16, 2014 Report Posted May 16, 2014 If it were me I'd add another battery and call it a day. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
jdshott Posted May 17, 2014 Report Posted May 17, 2014 Like I said adding a REGULAR CAR BATTERY has MAJOR RISK . And you can add as many batteries as you would like . yes your factory can charge 2 maybe 3 batteries and have no problem . But you will still see major voltage drops and possibly damage your equipment or parts . IMO 6 batteries may help , but OHMS LAW says otherwise. No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
95legwagon Posted May 17, 2014 Report Posted May 17, 2014 Like I said adding a REGULAR CAR BATTERY has MAJOR RISK . And you can add as many batteries as you would like . yes your factory can charge 2 maybe 3 batteries and have no problem . But you will still see major voltage drops and possibly damage your equipment or parts . IMO 6 batteries may help , but OHMS LAW says otherwise. just sayin..... been running 4 total (including under hood) lead acid batteries in my hatch on a stock 80a alt for well over a year in a half no problem. vented outside of course, im easily over 1000 rms with power hungry amps. no voltage drop at full tilt for quite awhile driving time. never had an issue. yea they arent made for charge/discharge cycles like I use them for......BUT they work and HAVE been working for quite awhile considering i almost NEVER top them off. charging @ 14.6v cold and 14.3v hot. not the most ideal batt setup but it does work...... edit: i know im not pulling alot of current from my alt but its definitly over 80 amps. OH and had almost no voltage drop with 2 batteries. i added more to play longer with NO drop i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
TeamHT Posted May 17, 2014 Report Posted May 17, 2014 Juicebox is having an awesome deal on their black cherries. Legit as shit battery Tell me...does this smell like chloroform to you?
FCS530 Posted May 17, 2014 Report Posted May 17, 2014 I have been running 3 of the Napa AGM batteries in my 2 systems. They are around $150ish. Next cheapest for an AGM would probably be optima. There might be others but the safest thing for inside the vehicle is AGM. And if you put 1 AGM in the mix, it is best to make them all AGM. Several systems, several vehicles. Always changing! 2013 MECA State Champion (trunk 1) 2014 MECA State Champion (mod 4) 2014 MECA state Champion (Park and Pound 4) 2014 DBDRAG 6th place North America Finals (SS1-2) 2014 BASS RACE 6th place North America Finals (139.9)
poorfish88 Posted May 17, 2014 Report Posted May 17, 2014 I have been running 3 of the Napa AGM batteries in my 2 systems. They are around $150ish. Next cheapest for an AGM would probably be optima. There might be others but the safest thing for inside the vehicle is AGM. And if you put 1 AGM in the mix, it is best to make them all AGM. I'm running a group 34 and a big H8 AGM Adance Auto Parts Batteries got super cheap deal with retail me not. Pretty sure Advance AGMs are made by Johnson Controls.
tayodell41 Posted May 17, 2014 Author Report Posted May 17, 2014 Juicebox is having an awesome deal on their black cherries. Legit as shit batteryHow do I find these batteries?
