Alright so today I shaved off the amp mounting feet...really happy with it....just used a sawsal lol worked great!
Then desoldered these guys apart so I could use them in the amp
Like so
Even have covers for them :)
My dremel cutoff wheel supply is empty so had to do the second one like this lol...cleaned it up with a grinding bit looks fine
5.0k all stripped
now I have an external fuse for all the guages and fans :)
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
Awesome work, oh and according to tony damore. Iirc he said the devices need like .1a each... I was inquiring about the tm1 in regards to how many fans it can run and if I have multiple smd devices on the same 5a fuse required on it for both fans and the devices.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I am running 6 fans 3 pushing 3 pulling...they are tiny thin profile 40mm fans that are not as power hungry as your average 80mm-120mm computer fans.
Pretty sure the manual says it can power 4 fans, if you go more than that you will need a relay but I didnt want to run more wires and stuff so when I tested it it the fans seem to have as much power running all 6 full spead as it does when I hook them up individually to a battery....meaning they dont seem to be underpowered.
as for running multiple smd devices on the same fuse fans included(I think thats what you are asking?) I dont see why I shouldnt be able to run the three gauges and 6 fans off of a single fuse....how big I dont know yet I will hook up my fuse tested and turn everything on and get the fans going full blast and see how many amps it pulls and fuse accordingly.
Hope thats what you mean.
Well... Sort of,
Damore said the max is 5a.
So you can power 10 of the 90mm fans that I use, or about 50smd devices... Or any combination that is under 5a :)
That's directly from tony. The tm1 just can't see more then 5a
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Oh I get yeah...yeah I will be well under that haha, probably going to need like a 2-3 amp fuse max lol!
well not related to my 5.0 k's but I got my center console done with the 4 smd guages vm-1 tm-1 and 2 om-1's so here's a money shot of those!
mids and highs are playing on om-1 to the mids and the other to the tweeters for now...once subs are in I'll switch out my mids for the subs for the om-1's
Also I dont think I'll stay with these switches...probably get different style one that light up blue :)
Well they are in..having tuning issues but they are wired and mounted...led's aren't wired up the guages are
Just a few more things and some tlc and then bass should be pounding!
  • 1 month later...
Added some more rgb's to the back these ones are slightly different in looks and after powering them up they dont exactly match the ones in the amp but they are close..I think I paid like 5-6 bucks for the pack
I put 2 in the port 3 over the buss bars 2 inside each mids and highs amp rack so lights up quite a bit better this way
soldered everything
result :)
[/url]
and a little vid walk around of the new improvements
DONT FORGET TO CHECK OUT SOTM!!! ONLY 56 PEOPLE HAVE CAST VOTES..KINDA SAD! Edited by goodvibez
wow bro, that really came out great!!! I love it!! I would love to see those OM-1's dancing if you ever feel like making a video of them in motion :D Loving the RGB everywhere!
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
