dblovah51 Posted May 24, 2014 Report Posted May 24, 2014 im about to do an enclosure for the new db drive wdx3k subs for someone, its a new line from db. the manual reccomends 3.7 cubes per 12" i thought it was a bit much so i called db tech and he told me around 1.5 cubes should be good, so am confused lol 1.5 is a long way from 3.7cb they stated in the manual for optimum. any advice appreciated. 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
afrakes Posted May 24, 2014 Report Posted May 24, 2014 I would guess he meant 1.5 sealed. That would put ported in the 2.5-3.5 range I would think. Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
P4killer_ Posted May 24, 2014 Report Posted May 24, 2014 I mean ive never personally ran a 12 in anything bigger than 2.5cuft ported. So imo that iss a bit much (3.5cf) for a car stereo application. Especially for a simple ported box. I would just double check that figure. Call em again if you have to. Its not that 3.5 wouldnt work, just make sure to stick to recommended power levels and dont play below tuning too much etc. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Cj Kumz Posted May 24, 2014 Report Posted May 24, 2014 im about to do an enclosure for the new db drive wdx3k subs for someone, its a new line from db. the manual reccomends 3.7 cubes per 12" i thought it was a bit much so i called db tech and he told me around 1.5 cubes should be good, so am confused lol 1.5 is a long way from 3.7cb they stated in the manual for optimum. any advice appreciated. The manufacturers know what their doing, though on 12s I have never even reached 3 cubes lol. But that recommendation should be ok especially if you don't over-power the subs Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
REH Posted May 24, 2014 Report Posted May 24, 2014 Don't manufacturers typically "recommend" a much smaller than the true "optimal" large size box... to be more appealing to the average buyer? In this case they've blown that out of the water by far... And are recommending a box size that is unheard of.
TRON Posted May 24, 2014 Report Posted May 24, 2014 It does seem like a lot of volume only because it is a ''competition'' subwoofer. It really depends on what you want out of if. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Nightshade Posted May 24, 2014 Report Posted May 24, 2014 15 years ago 12" sub's were getting reccomendations like that from manufacturer's for a ported enclosure. I can remember the Vega series woofers had a reccomended size for deep bass at 3 cubes. Now a days this is very unnecessary due to the ridiculous amount of power being run and the improvements on subwoofers themselves. Back then your average loud system was maybe 2 amps that did 1000 watts tops, and a pair of sub's. Shit has changed quite a bit. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Purplehaze Posted May 24, 2014 Report Posted May 24, 2014 3.7 is fine if your running low to medium power. Bigger box is how you get loud on low power.It would cause problem at higher power, usually the more power you want to throw at a sub, the smaller the box needs to be. But it also depends on what you want to tune the enclosure to. I'd personally try to get it in the 2 - 2.5ft^3 range. Or smaller if your running a ton of power to them. I had my three 12's in 7.5 cubes total, @33hz, and they loved it, and sounded awesome. Until I gave them too much power.... Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
Joe X Posted May 24, 2014 Report Posted May 24, 2014 If the volume is correct (and I have not seen any specs) looks like you could fit 2 15s in the same space, better those have awesome excursion or something else great going for them, otherwise seem to me like an awful waste of space.
dblovah51 Posted May 24, 2014 Author Report Posted May 24, 2014 thanks guys 3.7 does seem like a bit much so ill do it at about 2.5 with 40sq port per sub. not exactly sure on the exact power this guy is goin to run to the sub but knowing him he'll be above rms. 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
