Triticum Agricolam Posted June 1, 2014 Report Posted June 1, 2014 Box doesn't look bad, one suggestion though, try to make the baffle piece on the outer part of the box. It adds quite a bit of strength to the baffle. Hope that makes sense...lol I understand what you are saying, but how would it be any stronger than the way he did it? Its a butt joint either way. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
g2shuck Posted June 1, 2014 Report Posted June 1, 2014 Notice Torres says physical port length is 19.5 inches 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
timc31610 Posted June 1, 2014 Report Posted June 1, 2014 Box doesn't look bad, one suggestion though, try to make the baffle piece on the outer part of the box. It adds quite a bit of strength to the baffle. Hope that makes sense...lol I understand what you are saying, but how would it be any stronger than the way he did it? Its a butt joint either way. For one the baffle would be 1.5" larger on both sides ( width and height), in his pic on the top and bottom of the speaker there is only about 1/4" or less of baffle where the way I mentioned there would be 1" on the top and bottom. Secondly, he will be screwing his sub into the top and bottom of the box instead of straight into the baffle. I may be completely wrong Triticum, you have much more knowledge than I do and way better skill! My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
BRodgers Posted June 3, 2014 Author Report Posted June 3, 2014 Notice Torres says physical port length is 19.5 inches I did see this, but I also saw that the hz was at 33.14 so I thought a 26" port length would give me 33hz? I wish Torres would give the port baffle measurements in the cut list along with the rest of the enclosure. I think my port boards were [email protected]"x11.5" and [email protected]"x11.5" glued and screw to form an "L"..........The total length ended up being right at 26" so I thought it was perfect? I just wanted to double check. 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio
timc31610 Posted June 3, 2014 Report Posted June 3, 2014 It isn't the length of the wood that determines the tuning. It is the distance down the center of your port. For example if your port were 4" wide you would draw a line 2" away from either wall down the length of your port and measure that line. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
Triticum Agricolam Posted June 3, 2014 Report Posted June 3, 2014 Port calculations are only an estimate at best. The only way to know for sure to test it and see where you are at. If you are off a couple Hz in either direction you are never going to know the difference anyway. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
BRodgers Posted June 3, 2014 Author Report Posted June 3, 2014 Alright, I'll stop worrying about it. Subs and Amp will be here next week. I'll get to painting the box and leave it be. Thanks for the advice everyone! 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio
bassman619 Posted June 3, 2014 Report Posted June 3, 2014 Yea my opinion leave it how it is ..you did a good job on bracing btw..a few pointers for next time..when you put on the wood glue ..spread it out with your fingers so it will be evenly spread on the mating surfaces and not drip so much ..also try to predrill out your holes for your screws it will prevent the mdf/wood from cracking/splitting..or you could just use a nailgun instead of screws You need trunk space to get groceries and shit...bitches love groceries
bassman619 Posted June 3, 2014 Report Posted June 3, 2014 Also if building for a trunk car the most effective design for two sub would be subs firing forward into cabin and port in the middle..either wag its your 1st box..im sure youll be happy with it but the more you build the better youll get You need trunk space to get groceries and shit...bitches love groceries
BRodgers Posted June 11, 2014 Author Report Posted June 11, 2014 This is what I've got so far... Thanks for all of the advice guys! 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio
