harlemn8ive Posted May 31, 2014 Report Posted May 31, 2014 looking for some help designing a box. the problem is i only have 31 inches width 16 inches height and about 40 inches depth. the subs are 2 Sounqubed hds312 looking to tune it low. i have made several attempts to make this box without success all because of the dimensions any help would be highly appreciated. i have ran into problems with the port size as well as the subs are actually 12.5 inches total. don't know if it matter but i will be running them off a ct sounds 1400.1 Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
timc31610 Posted May 31, 2014 Report Posted May 31, 2014 What port/sub configuration are you looking for? Sub/port back, 1 up 1 back? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
harlemn8ive Posted May 31, 2014 Author Report Posted May 31, 2014 port forward sub forward looking to seal off trunk Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
slowfkncar Posted May 31, 2014 Report Posted May 31, 2014 Wayyy more then enough room. Try 25l 30d 16h /port 30l 4w 14.5h *edit. Sorry but i totally calculated your maximum width incorrectly
harlemn8ive Posted May 31, 2014 Author Report Posted May 31, 2014 4(port)+ 12.5(sub outer (circumfrence)+12.5+wood(1.4)=30.4 thats basically how i built it but it would look like this see how flimsy the wood would be Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
harlemn8ive Posted May 31, 2014 Author Report Posted May 31, 2014 It may work if i make the port 3 inches wide it may work but not sure of the adverse affects of this Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
harlemn8ive Posted June 1, 2014 Author Report Posted June 1, 2014 sat down rethought it all and this is what i got... thanks for the help front rear Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
