Little Somthing I Have Been Devoleping
Hey all, in my spare time from work i devolep apps as a hobby.
I'm devoleping a simple music player.. in C# & VB.net 08
Right now it's only Vista user oriented..
Here's a screen shot of what i have so far, (About 2 & 1/2 hours worth of work)
(Click for a bigger View)
Posted Image
looks good, whats left to finish on it?
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
Well here's the list of things i set for it, Anything with an X has been finished
'Sharp Media Version 7 :: Vista only
(x) Extend Glass
(x) Vista Themed Glow Text
(x) VU Meters
(x) Music Engine
(x) 3D Album Art
() Dynamic Playlist
() Album Art in playlist
() Playlist Layout Defined by artist
() Play, Stop, Pause, Next, Back buttons
() Volume Slider
() Load a Folder of Files
() Drag and drop Support
() Trackbar
() TaskBar intagration
() Plugin Engine
() Updater
() Code Signing
() Installer
Also maybe a sidebar Gadget.
And the side project to go with it, a Complete Tag editer, Not started.
Thanks all
i like that. i'm going for computer programming and i'm lookin so forward to making things like this for my personal use
That's neat what do you plan to do with it after you finish creating it. Just for personal use?...
It's just a hobby, i don't see why i can't share with others.
Free to download when it's finished!
Here's a little programming that's going into it.
Figure it out. shouldent be to hard. it's pretty straight forward
private void SMD()
Process LaunchSMD = new Process();
LaunchSMD.StartInfo.FileName = "http://www.stevemeadedesigns.com/";
LaunchSMD.Start();
private void Button_Click(object sender, EventArgs e)
SMD();
private void SMD()
LaunchSMD.Start();
SMD();
Ughh a function call to start stevemeadedeisgns.com? not hard.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Bingo.
No it's not hard
Here's Alittle VB .. maybe harder.. maybe not.
Private Sub Rotate_Img()
Dim bm_in As New Bitmap(picSource.Image)
Dim wid As Single = bm_in.Width
Dim hgt As Single = bm_in.Height
Dim corners As Point() = { _
New Point(0, 0), _
New Point(wid, 0), _
New Point(0, hgt), _
New Point(wid, hgt)}
Dim cx As Single = wid / 2
Dim cy As Single = hgt / 2
Dim i As Long
For i = 0 To 3
corners(i).X -= cx
corners(i).Y -= cy
Next i
Dim theta As Single = Single.Parse(-5) * PI / 180.0
Dim sin_theta As Single = Sin(theta)
Dim cos_theta As Single = Cos(theta)
Dim X As Single
Dim Y As Single
For i = 0 To 3
X = corners(i).X
Y = corners(i).Y
corners(i).X = X * cos_theta + Y * sin_theta
corners(i).Y = -X * sin_theta + Y * cos_theta
Next i
Dim xmin As Single = corners(0).X
Dim ymin As Single = corners(0).Y
For i = 1 To 3
If xmin > corners(i).X Then xmin = corners(i).X
If ymin > corners(i).Y Then ymin = corners(i).Y
Next i
For i = 0 To 3
corners(i).X -= xmin
corners(i).Y -= ymin
Next i
Dim bm_out As New Bitmap(CInt(-2 * xmin), CInt(-2 * ymin))
Dim gr_out As Graphics = Graphics.FromImage(bm_out)
ReDim Preserve corners(2)
gr_out.DrawImage(bm_in, corners)
picSource.Image = bm_out
FixImage(picSource, picDest, True)
End Sub
Private Sub FixImage(ByVal from_pic As PictureBox, ByVal to_pic As PictureBox, Optional ByVal anti_alias As Boolean = False)
Dim from_bm As New Bitmap(from_pic.Image)
Dim wid As Integer = from_pic.Width
Dim hgt As Integer = from_pic.Height
Dim to_bm As New Bitmap(wid, hgt)
Dim gr As Graphics = Graphics.FromImage(to_bm)
If anti_alias Then gr.InterpolationMode = Drawing2D.InterpolationMode.HighQualityBilinear
gr.DrawImage(from_bm, 0, 0, wid - 1, hgt - 1)
to_pic.Image = to_bm
End Sub
Private Sub LoadPicture()
m_PictureFrames = m_UltraID3.ID3v23Tag.Frames.GetFrames(MultipleInstanceFrameTypes.Picture)
m_PictureTypes = HundredMilesSoftware.UltraID3Lib.ID3PictureFrame.PictureTypeList
lst_PictureType.DataSource = m_PictureTypes
m_PictureIndex = -1
'tpg_Pictures.Text = String.Format(c_TabFormatText_Pictures, m_PictureFrames.Count)
If m_PictureFrames.Count > 0 Then
m_PictureIndex = 0
End If
EnablePictureButtons()
End Sub
Private Sub EnablePictureButtons()
Dim PictureFrameCount As Integer = m_PictureFrames.Count
If PictureFrameCount > 0 Then
m_CurrentPictureFrame = CType(m_PictureFrames.Item(m_PictureIndex), ID3PictureFrame)
With m_CurrentPictureFrame
If m_CurrentPictureFrame.Picture IsNot Nothing Then
Me.picSource.Image = m_CurrentPictureFrame.Picture
End If
lst_PictureType.DataBindings.Clear()
lst_PictureType.DataBindings.Add("SelectedValue", m_CurrentPictureFrame, "Type")
'txt_PictureDescription.DataBindings.Clear()
'txt_PictureDescription.DataBindings.Add("Text", m_CurrentPictureFrame, "Description")
End With
'btn_DeletePicture.Enabled = True
If PictureFrameCount > 1 Then
Else
End If
Else
Me.picSource.Image = My.Resources.no_art
End If
Rotate_Img()
End Sub
That one is quite hard don't understand much of it. What does it do? I was learning a bit of VB I need to get my reading and practice with it. How did you learn what you know?
