so whats the verdict does the skin effect apply to dc or not.
i always thought fine stranded wire had more surface area = high amp ratings
thanks for all the answers so far btw
i have this stuff called nalox i use for terminating Aluminum cables
will that help my copper contentions if i used solid wire from nys salty roads lol
No, Skin Effect does not exist in DC current.
Krakin's Home Dipole Project
the more pressure you can generate on the connection points the better.
Hammerdown... 1%
i installed the new ground but i didn't really see any improvement of voltage
what should i do now
i got a
kic 1200 batt in rear
stock battery front
one run of ofc 0 gauge
big 3
im running
1 aq 2200 at 2 ohms
lanzar 250.4
rf 850.4
im dropping to 11.8 in front
full tilt at 2k rmp
Check where you did your big3. Might have chosen a poor engine to battery ground point.
Also are you running stock alt? If so that is likely the issue.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 1332 Guests (See full list)
