Driver cooling VS amount of port ?!?!?!
While dry ice would be cool to play with, C02 has a higher density than air and would be cold which would add to that density putting alot of strain on the subs which would work harder creating more heat and negating any possible cooling affect it may have.
Show me what you got.....
Me, im to the point i shorted myself on port area. That said, i like the way it plays. I could cut my baffle, but, to hell with that. If i go that far, its all coming out, and a 4th order with 2 more subs will go in. So, it is what it is, and ill just monitor it. Monitor it with it at full tilt for 6 songs in a row. :shrug:
I would think lower port area, more port pressure = higher rate of air exchange and better cooling.
That was the entire point of this thread. My brain saw it the same way.
Also, lower play would move the cone more, ya know, area wise, but, higher, would move it faster. So, isnt that a wash also?
Seems that way, although longer excursion pushes the air further out of the port allowing it to mix with air outside the box than a shorter faster motion would.
Excursion does not control air movement inside a port. At the point in which the most air is moving is the tuned frequency. The amount of Port area is mostly determined by cone area and tuning, with Xmax being for the allowance of the maximum. If you cut low on port area you are not allowing more air in you are forcing less air to moving to fast to be controlled. With the correct port area you will get the correct volume of air (more mass = better heatsink) moving in a controlled fashion. If you cut the area you sacrifice all that and then you face the problems of worse port compression and increased power compression; both of these affects will DRASTICALLY change the T/S Parameters of the driver(s) in question for the worse and will need an enclosure designed around the parameters of the sub(s) with a hot coil and other movies from mass along with new magnetic properties instead of the cold measured parameters.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
