Home audio guys, get in here.
I'm looking at doing a budget set up for my new tv. I have some 6.5in rf t2 comps laying around, and I want to buy 2 18in fi car audio IB3s. I was planning on running a crown Crown XLS 2000 DriveCore Series Power Amplifier. My question is can I run one channel at 2 ohms and the other at 4 ohms?
Team Bass-Hz
Home equipment and commerical equipment likes 4 ohms. Run 2 500 watt amps here with electronic crossover. I use a seperate Adcom turner to turn up bass. You wont need 18 in home audio. Stick with 15 or smaller.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I'm going to use 2 rf t2 comps in a passive type set up and the final load it give me is 4 ohms, and I wanted to run the subs at 2 ohms to maximize the power of the amp. Subs are 550 watts rms. I have the space for 18s so I might as well.
Team Bass-Hz
I always thought that home Audio liked to be run at 8 ohms for safe operation ...
Yes, but I will be using a pro audio amp and it can be ran safely at 2ohms. The subs, mids and highs aren't what you would consider "home audio" it's just stuff I have laying around.
Team Bass-Hz
Well took a little bit to find a manual for the amp. And to my surprise it is 2 ohm stable. So yes you can do what you are wanting to do.
So I can run one channel at 2 ohms and one channel at 4 ohm?
Team Bass-Hz
Well it's a 2 channel stereo amp. So run it either 2 or 4 ohms. You really need 2 amps. One for your mids and one for your subs.
truthsayer
I figured but I wanted to save money. I'm not trying to go all in on a this project, which is why I wanted one amp for everything.
Team Bass-Hz
