Good Response Curve?
timc31610
don't worry to much about response curve since it'll change slightly based on our vehicle. port velocity is a bit more concerning since you'll be able to hear port noise easier.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
I don't know anything about BassBoxPro so I don't know if your frequency response graph includes cabin gain or not. If it does then yeah that does look pretty good. If that graph is before cabin gain your box is going to end up sounding pretty peaky. You can tune lower and make the box smaller to get rid of the peak.
Your port velocity looks perfect though.
Builds:
i'd try to get that PV in the 20s
Here is the box, I will eventually make two exactly the same for two HDS312's. I want the ability to pull one out when I have to use my back seat.
It will be sub/port up. I will double baffle the top for flush mounting.
Here is the port
Suggestions are welcome!
i'd look into an aero port since you're planning a rectangle port.
I'm doing a slot port, will be 12.5" x 3.25. It will be the width of the box and 27" long. It will have a bend but I will 45 the inside corner and round all the edges. I know aeros are more efficient but that is more money I don't really need to spend.
Why?
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3394 Guests (See full list)
