coil rub
rsfm089
So I tested my subs coils both read 4ohms but there is coil rub when I push the cone to the side r they done or is there a way to fix these 4th gene alpine type R's
When I push straight up and down there is no coil rub
Yes but they sound like sht I wish I could post a video. I'm not even using them anymore so I was going to sell them but I don't want to sell someone some bad sht.karma is a botch
Check the magnets and see if one has shifted over.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
The magnet is the big heavy thing at the bottom. There may be a rubber covering over it known as a boot. You can most likely slide that boot off to see the magnets. They should all be in line with each other. If one isn't it will be clearly obvious.
Oh, it does have a fully covered magnet then you may be SOL. Sorry I didn't check that first.
If you have a warranty, use it.
Also, try a free-air test.
Take it out of the box and play a low volume signal through it, if no noise is evident then slowly turn up the volume. You may just have a bad box.
  • Who's Online   0 Members, 0 Anonymous, 2647 Guests (See full list)
