Caps! Need some advice and help
What are the dimensions per cap?
Where are the buss bars sourced from?
Explain this balancing system
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
dimensions of cap itself or the complete bank?
caps them selves are 2.5 inch diameter by 6.5 inches tall. 8 banks with my bus bars were 16.5 by 19.5.
bus bars that i did were made by toolmaker. I designed them in google sketch up and sent him the drawings to make.
i designed them to be able to run a continous 1600 amps which is a safe operating load for the 8 banks of caps
the banks are hooked up in a parallel series configuration. so 8 caps in a parallel config balance each other since they are in parallel. you count on tolerances being plus minus20% each way. so they level each other out.
to keep close balancing you want to limit the series connections to 6.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
What's typical price if a single bank?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
i wouldnt buy those ebay ones. you are paying for used caps that were probably used daily in a bus. they do have a million cycle life and many people run used caps but the price is a little steep. id say 300 for used caps is most id pay for the new 2.7 volt ones. plus those are active balancing and are good but passive is what you want when you arent pushing tyhe limits on these.
a typiocal new bank is around 350. and can support 2-2.5k with good wiring. and a H/O alt
BMW M340 xDrive
Mouser had em brand new for less than that
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dont know what mouser you are looking at, but this has been the price since i have started looking at them.
57 a piece if you buy 25 which is 4 banks. so thats 342 plus ship per bank caps only
http://www.mouser.com/Search/Refine.aspx?Keyword=bcap+3000
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
