2013 3.8 Genesis Coupe Track **When Speed meets Bass**
*Update* My wufers came in! Shout out to DroppinHz. Got a super deal and came in real quick. 2 DC lvl 2 12'"s. Just a little ring trimming to do and they'll fit like a glove. Measure out for what my port will need to be and one box will be in permanently. About to get to work on the second box as well and while I'm at that I'll be doing my Nexus 7 into the dash. Get to work time.
Just doin' my thing in the car audio. Still working on getting build forums up.
Gen Coupe
http://www.stevemeadedesigns.com/board/topic/188409-2013-38-genesis-coupe-track-when-speed-meets-bass/
Man this makes me want to put something like that in my mom 2010 2.0T. That looks awesome and so slick. Did yours have the Infinity system in it with the sub?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Thanks, and yes the infinity system, I'm keeping those for a while til I can afford something real nice like some T3s most likely. I am going to put them on a Skar amp and I got a PAX 8" mid bass driver to replace the stock one. I'm waiting on my amps now a Skar T1400.1D for the subs and a T60.4-200.1AB for the mid and other components that I'll be getting.
Gen Coupe
Working on it now. Measured volume last night, cut hole for port and installed port tonight, waiting for that to dry and harden and the tomorrow I'll smooth it out and repaint that area. Finished opening up the inner ring to fit new sub as well. Holes drilled for T-Nuts, but I need longer bolts because I grabbed the wrong ones. Also taped off the other side of the trunk for box #2. I'll post pics in a few.
Gen Coupe
That is a nice enclosure. did you paint or wrap it. looks like wrap to me. if you did how did you get it around all of those curves so well? I am going to re-wrap my doors soon and that's the main issue I had the first time around.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Thanks, it's truck bed liner actually. Wrapping would be a long tedious job on this.
But if your going to wrap door panels or something with curves then having a heat gun handy helps a lot,also apply glue and allow it to tack up real well before you start to pull fabric. And then just work it. If you have an upholstery tool it helps get it tight.
Gen Coupe
