Guest Posted June 27, 2014 Report Posted June 27, 2014 as long as your car voltage doesn't drop much, you're fine on power feeding into the amp.
dharris2488 Posted June 27, 2014 Author Report Posted June 27, 2014 only easy way to fix it is to wire lower. get D1 coils, wire to 1 ohm. itll help. if you want, you can go below 1 ohm. i know a guy running four crescendo 5500's at .33 ohms daily and they're fine. your mileage may vary. i'd wire to half ohm, but thats just me. On strapped 2200's? SQ'ed? 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
Guest Posted June 27, 2014 Report Posted June 27, 2014 but mind you, every frequency will affect the woofers differently. some frequencies you may rise to 10 ohms, others you may rise to 1.5 ohms.
Guest Posted June 27, 2014 Report Posted June 27, 2014 only easy way to fix it is to wire lower. get D1 coils, wire to 1 ohm. itll help. if you want, you can go below 1 ohm. i know a guy running four crescendo 5500's at .33 ohms daily and they're fine. your mileage may vary. i'd wire to half ohm, but thats just me. On strapped 2200's? SQ'ed? oh LOL strapped 2200s? then if it was me, i'd do strapped at 1 ohm. so each amp sees .5. thats what i would do if i owned those amps. thats what i plan on doing with my 1200's once i get shit together in like 20 years lol but if you blow shit up, its not my fault
dharris2488 Posted June 27, 2014 Author Report Posted June 27, 2014 Ok. Yeah, those numbers were taken on a 40hz test tone, about 1 minute long. 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
dharris2488 Posted June 27, 2014 Author Report Posted June 27, 2014 Well, I will call Quentin at DSS and try to change my D2's to D1's... I think I should have the electrical, as I plan to add another battery or two. 2 runs of 1/0 as well... 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
dharris2488 Posted June 27, 2014 Author Report Posted June 27, 2014 only easy way to fix it is to wire lower. get D1 coils, wire to 1 ohm. itll help. if you want, you can go below 1 ohm. i know a guy running four crescendo 5500's at .33 ohms daily and they're fine. your mileage may vary. i'd wire to half ohm, but thats just me. On strapped 2200's? SQ'ed? oh LOL strapped 2200s? then if it was me, i'd do strapped at 1 ohm. so each amp sees .5. thats what i would do if i owned those amps. thats what i plan on doing with my 1200's once i get shit together in like 20 years lol but if you blow shit up, its not my fault I'm coming to find you if my shit blows up and my car catches fire! lol 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
Kyblack76 Posted June 27, 2014 Report Posted June 27, 2014 (waits for shit to blow up, and op asking if anyone knows that KRANNY guy) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted June 27, 2014 Report Posted June 27, 2014 (waits for shit to blow up, and op asking if anyone knows that KRANNY guy) good thing the people that know where i live dont go on this forum
