Hey I just have a quick question about the dd-1 for all those more knowledgable than me. So I set my gains with my truck at 13.8 volts and no clipping. Then, when I'm bumping my system will drop to about 12.2-12.5 volts on the big notes when it's turned up to max (the point just below clipping when it's at 13.8 volts. Since there is less voltage, will my amps clip now or just make a less power? Thanks
I don't know the right answer but I do know this is why I bought a om-1 lol
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
add electrical support if your voltage is dropping on a clean signal. Also, is your music source the same db as the track you used to set with DD1 ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
