Orion hcca 10.2 NEW not sounding good at high volumes
Yeeb
Before you buy a HO alt, have your 0 gauge power and ground wire installed, have your 0 gauge big 3 installed, have the amp properly tuned, a proper ground and also have a good size speaker wire from your amp to sub.
Pushing it to the limits. Want more power.
You don't need a HO alt with that power.
Big 3 and replace cap with a small agm battery and your good to go
You need to order wiring first my friend. The HO alt won't do anything when you got to small of wire while not having a good "install"
Then that will be better but what you need to do first is upgrade your power wire and ground!!! Not 8awg or some cheap 4awg. Get some 1/0awg and do the big 3
Your biggest issue is your wiring bro.
You can't try to force more power thru small wire, your create more heat and more resistance and then boom! You got a fire
You need a better ground and better wiring and then worry bout a battery
Does anyone else not agree with this?
  • Who's Online   1 Member, 0 Anonymous, 1405 Guests (See full list)
