Soccerballzs Posted July 2, 2014 Report Posted July 2, 2014 I ran single 10 hcca for years. You will need to break in they will smell the first couple weeks. Do not use a subsonic filter set to low it will sound bad. What size box are you using? Hifonics will run hot and not sound as clean as a better quality amp. But it will work for now. Watch gains. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Yeeb Posted July 2, 2014 Author Report Posted July 2, 2014 2 cubic foot box for a 12 sealed with the plate it came shipped in for a 1.5" baffle. And I meant it didn't sound to me like the ground from engine block to chassis had anything to do with the alt. just seemed like bolt to bolt with no power source. At least the way it's worded
OrionStang Posted July 2, 2014 Report Posted July 2, 2014 The alt grounds to the engine block by its case/bolts, the engine block grounds to the frame. Make sense now? SMD Super Seller My Feedback Thread
Guest Posted July 3, 2014 Report Posted July 3, 2014 The alt grounds to the engine block by its case/bolts, the engine block grounds to the frame. Make sense now? yea and the rubber motor mounts are between the frame and engine so when you ground the alt to the block it dont go past the mounts so easy to the frame
OrionStang Posted July 3, 2014 Report Posted July 3, 2014 The alt grounds to the engine block by its case/bolts, the engine block grounds to the frame. Make sense now? yea and the rubber motor mounts are between the frame and engine so when you ground the alt to the block it dont go past the mounts so easy to the frame Which is why you add the engine block to frame wire, right? SMD Super Seller My Feedback Thread
OrionStang Posted July 3, 2014 Report Posted July 3, 2014 This fucking guy. SMD Super Seller My Feedback Thread
Yeeb Posted July 3, 2014 Author Report Posted July 3, 2014 Welllll. Update. Took out cap and bass boost voltage from battery 14.4 while bumping at idle for about 5 minute. After it barely drops. Barely. Probably still at 14. While driving doesn't even flinch after an hour of bumping. It's at 4 ohm (800w) at the moment. Gonna check out 1 ohm (1600w) tomorrow And see. Thanks guys! Will keep updated after big 3 and yellowtop added.
Yeeb Posted July 3, 2014 Author Report Posted July 3, 2014 And 0 guage ground and power. Old power wire from first system (8 awg) will be speaker wire afterward.
