hdorre Posted July 2, 2014 Report Posted July 2, 2014 I know there are a few guys here that can weigh some input.. So I figure Ill try here too.. Last night when I was driving to my moms store, I felt my clutch pressure decrease with every shift. When I got to the store, I lost almost all pressure. In short, my stepdad was able to drive the car home. He mentioned pumping the clutch pedal and avoiding all red lights. This morning, I went to my car in the driveway. I felt the clutch, and it was pretty heavy. I turn my car around. By the time I turned it around, pressure was declining with every time I hit the clutch. I just got back from work (left the car in the driveway for like 8.5hrs), and felt my clutch. Theres nowhere near as much pressure as there should be, but theres a good amount more than last night. I pressed it a few times, and with each push, the pedal pressure decreased. Last night, I didnt see any fluid behind my clutch pedal or any fluid dripping under my car from leaks. The clutch fluid reservoir seemed to be unchanged too. My plans are to replace the master and slave cylinders.. what else should I look at? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
youngbass98 Posted July 2, 2014 Report Posted July 2, 2014 possibly the pressure plate that's what went on my dad's Subaru. or possibly air in your hydrolic line. but new master and slave cylinders would probably do it 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
OrionStang Posted July 2, 2014 Report Posted July 2, 2014 Sounds like the slave cylinder. Im not completely familiar with the setup on your car. Is the clutch system separate from the braking system? EDIT: Answered my own question. Gotta be the master or slave cylinder if fluid level is unchanged. SMD Super Seller My Feedback Thread
hdorre Posted July 2, 2014 Author Report Posted July 2, 2014 possibly the pressure plate that's what went on my dad's Subaru. or possibly air in your hydrolic line. but new master and slave cylinders would probably do it Better not be the PP. I got an ACT Kit installed 2yrs ago, with the HD Pressure Plate. Im nowhere near its max rating yet. Sounds like the slave cylinder. Im not completely familiar with the setup on your car. Is the clutch system separate from the braking system? EDIT: Answered my own question. Gotta be the master or slave cylinder if fluid level is unchanged. You're one of the people I was hoping who'd enter. Someone else also mentioned the clutch fluid line, but i ruled that out bc no leaking. The systems are separate, as you found. Im hoping its one of the two.. because Im about to just order both. Installation is gonna be a bitch.. the slave is in a weird spot. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
OrionStang Posted July 2, 2014 Report Posted July 2, 2014 On a quick google search, I found that if the slave is bad replace it. If the master is bad replace both. But I don't know how you'd tell which is bad LOL. They aren't too pricey at least, just a PITA. SMD Super Seller My Feedback Thread
hdorre Posted July 2, 2014 Author Report Posted July 2, 2014 Yea, I read the same. I figured id be safe and just replace both.. They aren't much cash. This slave is gonna piss me off. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Awhitewookie Posted July 3, 2014 Report Posted July 3, 2014 My slave started "leaking" air into the system but no fluid. Just had to replace it and everything is good to go MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Broke_Audio_Addict Posted July 3, 2014 Report Posted July 3, 2014 Sounds like the slave to me. Since you're going to replace both you might as well replace the lines too while you got it all apart. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
hdorre Posted July 3, 2014 Author Report Posted July 3, 2014 My slave started "leaking" air into the system but no fluid. Just had to replace it and everything is good to go I didnt think of that! I figured fluid would leak too.. Sounds like Ill be set.. Sounds like the slave to me. Since you're going to replace both you might as well replace the lines too while you got it all apart. You're like the 5th person to tell me this about the line. Added it to my list On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
fox_racin4 Posted July 3, 2014 Report Posted July 3, 2014 If its the stock slave Chances are its the slave. Personally i would do both anyways. Bleeding them is always a bitch...why do it twice? Also it can get air in the system with no fluid leak 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
