I know there are a few guys here that can weigh some input.. So I figure Ill try here too..
Last night when I was driving to my moms store, I felt my clutch pressure decrease with every shift. When I got to the store, I lost almost all pressure.
In short, my stepdad was able to drive the car home. He mentioned pumping the clutch pedal and avoiding all red lights.
This morning, I went to my car in the driveway. I felt the clutch, and it was pretty heavy. I turn my car around. By the time I turned it around, pressure was declining with every time I hit the clutch.
I just got back from work (left the car in the driveway for like 8.5hrs), and felt my clutch. Theres nowhere near as much pressure as there should be, but theres a good amount more than last night. I pressed it a few times, and with each push, the pedal pressure decreased.
Last night, I didnt see any fluid behind my clutch pedal or any fluid dripping under my car from leaks. The clutch fluid reservoir seemed to be unchanged too.
My plans are to replace the master and slave cylinders.. what else should I look at?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
possibly the pressure plate that's what went on my dad's Subaru. or possibly air in your hydrolic line. but new master and slave cylinders would probably do it
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Better not be the PP. I got an ACT Kit installed 2yrs ago, with the HD Pressure Plate. Im nowhere near its max rating yet.
Sounds like the slave cylinder.
Im not completely familiar with the setup on your car. Is the clutch system separate from the braking system?
EDIT: Answered my own question. Gotta be the master or slave cylinder if fluid level is unchanged.
You're one of the people I was hoping who'd enter. Someone else also mentioned the clutch fluid line, but i ruled that out bc no leaking.
The systems are separate, as you found.
Im hoping its one of the two.. because Im about to just order both. Installation is gonna be a bitch.. the slave is in a weird spot.
LMFAO so true
:blush:
Yea, I read the same. I figured id be safe and just replace both.. They aren't much cash. This slave is gonna piss me off.
LMFAO so true
:blush:
My slave started "leaking" air into the system but no fluid. Just had to replace it and everything is good to go
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Sounds like the slave to me. Since you're going to replace both you might as well replace the lines too while you got it all apart.
I didnt think of that! I figured fluid would leak too.. Sounds like Ill be set..
You're like the 5th person to tell me this about the line. Added it to my list :)
LMFAO so true
:blush:
If its the stock slave Chances are its the slave.
Personally i would do both anyways. Bleeding them is always a bitch...why do it twice?
Also it can get air in the system with no fluid leak
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1100 Guests (See full list)
