BAMABOY691 Posted July 10, 2014 Report Posted July 10, 2014 Ok I was getting ready to recone my 18's and the pole in the middle of the motor is all the way to one side. Is this fixable if so how [[
Miguels Posted July 10, 2014 Report Posted July 10, 2014 fixmyspeaker.com my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
audiofanaticz Posted July 10, 2014 Report Posted July 10, 2014 The pole isnt shifted, the top plate is. Its easy to fix, but a pain if you never done it. Your going to need some long screws the same thread as the holes to mount the basket (3 usually works). Going to have to screw them in with a drill going in increments from screw to screw and the top plate will start to lift up. Once your able to get your fingers between the top plate and magnets you can then usually pull it off. once you have it off, your going to want to clean off any old adheshive on top of the magnets and the bottom side of the the top plate. Your going to have to find something to evenly shim the top plate out so that the gap is going to be equal all the way around the pole piece. Sometimes PVC tube will work well, sometimes you need to cut it down into thinner strips. (you may need to add thin carboard shims with the pvc to make it a tight even fit all the way around. You dont want any slop. For doing it the easiest way stick the pvc shims around the pule and set the top plate on and see where your at and how much more you need to shim it out to be as centered as possible. Once you get that done you can take the top plate off again, and set your shims aside, and use some glue to put it back together. CA glue would work, otherwise 2 part expoxy with a long open time is your best bet.Once you have evenly applied glue around the top of the magnet slug you can then reinsert your shims, and get ready to put the top plate on again. Make sure you have the screws out far enough so your fingers dont get smashed between the magnet and top plate. then slowly start backing out the screws which will lower the topplate onto the magnet. Once you got the screws out, leave the motor to sit over night and allow the glue to cure. Also make sure you dont put any glue too close to the inside edge of the magnet slugs because it will ooze out a little and you dont want it to ooze onto your shims and gluing those into the gap permanently!
BAMABOY691 Posted July 10, 2014 Author Report Posted July 10, 2014 Thanks Audiofanaticz I'll give it a go .....anymore suggestions keep them coming
dolarbilz Posted July 11, 2014 Report Posted July 11, 2014 I want to try remove top plate.looks interesting to do.
BAMABOY691 Posted July 11, 2014 Author Report Posted July 11, 2014 I want to try remove top plate.looks interesting to do. All man it was eazy and I already fixed it
BAMABOY691 Posted July 11, 2014 Author Report Posted July 11, 2014 The pole isnt shifted, the top plate is. Its easy to fix, but a pain if you never done it. Your going to need some long screws the same thread as the holes to mount the basket (3 usually works). Going to have to screw them in with a drill going in increments from screw to screw and the top plate will start to lift up. Once your able to get your fingers between the top plate and magnets you can then usually pull it off. once you have it off, your going to want to clean off any old adheshive on top of the magnets and the bottom side of the the top plate. Your going to have to find something to evenly shim the top plate out so that the gap is going to be equal all the way around the pole piece. Sometimes PVC tube will work well, sometimes you need to cut it down into thinner strips. (you may need to add thin carboard shims with the pvc to make it a tight even fit all the way around. You dont want any slop. For doing it the easiest way stick the pvc shims around the pule and set the top plate on and see where your at and how much more you need to shim it out to be as centered as possible. Once you get that done you can take the top plate off again, and set your shims aside, and use some glue to put it back together. CA glue would work, otherwise 2 part expoxy with a long open time is your best bet. Once you have evenly applied glue around the top of the magnet slug you can then reinsert your shims, and get ready to put the top plate on again. Make sure you have the screws out far enough so your fingers dont get smashed between the magnet and top plate. then slowly start backing out the screws which will lower the topplate onto the magnet. Once you got the screws out, leave the motor to sit over night and allow the glue to cure. Also make sure you dont put any glue too close to the inside edge of the magnet slugs because it will ooze out a little and you dont want it to ooze onto your shims and gluing those into the gap permanently! So thanks to you I fixed it real quickly. I used the 2 part epoxy FI sent with the compression plug [[[
audiofanaticz Posted July 11, 2014 Report Posted July 11, 2014 Damn, that was pretty quick Its not really that hard of a thing to do, after you do it a few times it gets even quicker. Done it to about 8 different woofers for people. Really no need to send it off for someone else to do such a simple task and pay labor, and shipping both ways.
