magillaru Posted July 12, 2014 Author Report Posted July 12, 2014 100 amp fuses will be fine Really?? Not doubting you....that just surprises me. I was under the impression that the wire gauge was what determined the fuse size....? If my alt does 80 amp, but i use 8/0 gauge good for 500 amp, would you fuse to that? You dont have enough amperage to let a 300 amp fuse go..... Use the 1/0 but, fuse down.....to be safe. Makes sense. Thanks. Singer Alternators Team Asshole #anothershittysingerbuild
magillaru Posted July 12, 2014 Author Report Posted July 12, 2014 So even though the amp's internal fuse is 300, that doesn't matter (I remember reading something about this somewhere in here). And if I ended up upgrading the alt, then I would need to upgrade the fuses due to there being more amperage/current flowing through....? Singer Alternators Team Asshole #anothershittysingerbuild
Kyblack76 Posted July 12, 2014 Report Posted July 12, 2014 You dont have the GOODS to feed the amp dude? what does your stock do? are you wiring LOW? Like, .25 low? put a 150 in line.. if you ever blow it from volume, ill buy you more.... You wont... trust me. Put a 250 in, you might as well use the wire.... just me SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted July 12, 2014 Report Posted July 12, 2014 You buy a dc 10k that would pull 600 amp in a good situation. On a stock volkswagen bug. That can deliver 60 amps. What does the the NEED matter over what can BE made? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted July 12, 2014 Report Posted July 12, 2014 i have a 4 channel amp, that i up gauge. It only need around 70 amp. But i feed it a 1.0 wire. Would i fuse it to 300? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted July 12, 2014 Report Posted July 12, 2014 make sense bro? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
magillaru Posted July 12, 2014 Author Report Posted July 12, 2014 I have two 13W7s wired in series to 3ohms.....then the amp internally parallels them down to 1.5, correct? I would like to wire them down to .75 though..... Yeah, makes sense. Really appreciate the help - trying to learn as much as I can and trying to do everything myself (want to upgrade subs, alt, and amp next year). Singer Alternators Team Asshole #anothershittysingerbuild
audiofanaticz Posted July 12, 2014 Report Posted July 12, 2014 Kyler is right. Ive always fused this way, because its so much safer when your only fusing for what the requirement needs and maybe a tad headroom. Its pointless to fuse for the current rating of the power wire, especially if that power wire will never see that kind of current. Dont know how many times ive said it, but seems like only a handful of people can catch onto this concept.
magillaru Posted July 12, 2014 Author Report Posted July 12, 2014 Kyler is right. Ive always fused this way, because its so much safer when your only fusing for what the requirement needs and maybe a tad headroom. Its pointless to fuse for the current rating of the power wire, especially if that power wire will never see that kind of current. Dont know how many times ive said it, but seems like only a handful of people can catch onto this concept. Makes sense and even if the fuse goes for some reason, $6 is much cheaper than ruined equipment! I've been going by fusing for the rating of the wire but it never really made sense to me as to why I would need 300amp fuses when I'm not running much power in comparison to bigger systems. Singer Alternators Team Asshole #anothershittysingerbuild
