8 10s Walled SPL Issues
Wait you arent even sealed yet?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If your not doing a all out SPL build to be competitive then I always build to play the bandwidth I want and have the sound I'm looking for, if it does good numbers then so be it. I would start by maybe lowering port area with boards and that will lower tuning as well, see how it sounds. If you like it then you know what to do, if your goal is a high sealed score then you will need to look at ripping it all out and building for that goal. Mine falls on its faced sealed as well, about 4-5 db lower than opened up, but most would rather have a demo from mine than something built solely for numbers. You need to choose your goals and build for such.
my only real concern is the bandwidth, im going to seal off the sides soon that should help too. I really need to go do that this week,
You cant even judge whats going on until you seal off. My peak went from 43hz to 33hz just by sealing off the wall, I also gained 3db in the process between that and the subs breaking in. Your disaapointed without even knowing whats its going to sound like
2012 F250 Lariat 6.7, lifted on 22's and 35's
4 DSS Ethos 18's walled tuned low
2 Ampere Audio 7500.1's, Ampere 125.4
Rockford Pro Audio front stage
9 batteries, Mechman Elite 370 alt
Team DSS, Team Ampere Audio
2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
32d73d87-e373-4a49-8914-d25decfa6dcc_zps
I wouldn't look for a fix all either sealing off. I gain zero. Peak stayed. I'd expect a huge swing being that the wall in question was tested at a time where it was no where near sealed off. Like a box build and pushed in place.
That said. You have a quite a lot separation. Christ, from 2 hz.
I'm .3db with in almost 10hz.
Band width ftw. :shrugs:
how thick is the baffle? rear wave is probably getting choked cause the air has nowhere to go and the gap between the spiders and top of basket is really small
Thats how mine was, peaked high with it just in place. Changed huge with the trim panels and sealing off
More power man. You will probably be able to play lower and louder. Get another m4. Should be night and day difference.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Try this open your trunk lid and see how your bandwidth is
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
a lot of people that up power, LOSE on the low end.
If your pushing the drivers fairly hard now,.... adding enough power to score you better, edit - COULD CAUSE bottoming, softpart, (driver) issues.
Of course if you are WELL be low power, ... then of course it can only help, but, if your pushing them fairly hard now, and you had more power, that LOW LOW, will go BOOM BOOM......
Hes about a 3rd power from where id like to be
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 3242 Guests (See full list)
