Subwoofers not turning on but amp works. (so do subs)
OK guys so here's my issue, installed an entire new system, everything works, besides the subwoofers. The amplifiers both turn on, all the speakers turn on, my only issue right now is that the subwoofers do not turn on. I have plugged a left/right Rca to aux cable straight into the amp and played music off my phone and the subs do work so i'm narrowing it down to the signal cables. I've pulled out the headunit and doubled checked the rca cables, they are plugged in, I have tested the cables and they are getting a signal but the subs still aren't worked.
My headunit is an Alpine INE-957HD, I went into settings and enabled the subwoofer, it was off before, still no difference, I have turned the gain up and still no difference, at this point i'm at a loss, any help would be great guys!
So do the speakers play but just not the subs?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Check your ohms on your coils....
Subwoofer control turned all the way down possibly?
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Wiring is all good. Like I said plugged an aux cable into my amp and ran perfectly.
Yes there are 2 amps. One for speakers one for subs. Speaker amp and speakers are great and running well. Subs are not playing on 2nd amp but amp has Power and turns on. I left the amp on and plugged in my own cable. Runs and sounds well. I'm just thinking there's a setting in the head unit I haven't found.
maybe the RCA's for the sub woofer amp are bad?? just a thought
Black 1997 Honda Accord coupe 5 speed manual
Big three upgrade
all kicker 0 gauge wire
180 amp H/O DC power alternator
2 kinetik HC 1800's
Alpine iXA-W404 (FOR SALE!!)
2 Rockford Fosgate T1 D4 12's wired to 2 ohms (FOR SALE!!)
T1500-1 BDCP subwoofer amp pushing 1760 watts at 2 ohms @ 14.4 volts (FOR SALE!!)
(All items for sale have original boxes and birth sheet for the amp)
boss 6x9's 350 watts rms (maybe upgrading, want to put an amp to em and see what they can really do)
pioneer 6.5" component front speakers (upgrading soon)
no amp for the mids and highs yet...
Dynamated the whole trunk, doors next
Just got the SKAR Audio SK-4500.1D today!!! redoing the whole system! all in good time fellow bass heads :P
I didn't even think of that I will check that tomorrow morning.
Sorry this was supposed to quote the HPF post.
turn up subwoofer output on the head unit
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 930 Guests (See full list)
