problem with dd1
Hello
I am new to the forums so first off hello everyone and thanks for trying to help me solve this.
So my problem or what I believe to be the problem is setting the gains on my sundown saz 1200 when using the dd1 I will get a blip on the distortion detect led pretty much as soon as I move the gain knob but after I turn the knob further the distortion led light goes off and doesn't come on till I turn it up further currently I have the gain not even a 1/4 turn which does not seem right too me. Any help is appreciated
Hello
if it turns on and goes away after you turn it up a little more, its not bad, thats normal, its just the variable resistor, it could possibly have anything in the process that can cause distortion, like dirt or a bit of corrosion or some sort. You only need to worry about when it stays on fully and not when it just goes on like for a bit, is the light currently on a 1/4 turn and it has the light on fully? And some times that's all it takes to make the amp run at its full power.
Edited by Call Me Dubstep
2000 Ford Focus ZX3
Mods:
Raceland Coilovers
Borla Exhaust
Aftermarket Header
System:
Sony CDX-GT66UPW
Pioneer 6x8's
System Upgrades :
Pioneer MVH-X560BT
2 sets of Rockford Fosgate P1683's
Fi Audio Q 18" D2 ( Currently Own)
DD M1C ( Currently Own)
All SHCA Wires and stuff...
XS Power 4800 ( Stock Replacement)
High Ouput alternator (undecided which company or Amperage.)
All the settings are flat the rca outs on the headunit are 4 volt. The only setting that was not flat was sub level on headunit but the dd1 manual said to leave that at the middle setting so +7. I also have a second question when playing my sa 12s loud real bass heavy song my voltage will dip never below 13.5 I did the big three but when playing the subs full bore like this I sometimes notice a smell not sure if it's just glue melting off it's not a bad smell just something I noticed. I have not had the fortune of smelling what a burnt coil smells like and I find it hard to believe that is what it is. Since the sundown sa 12s and saz 1200 are overbuilt. But should I be concerned and if so would a good solution be turning the gain down like I said it's hardly turned up at all.
Hello
The distortion light was not solid it was like a faint blip never stayed solid but I was worried to turn it up more so I don't know what to do
Hello
That is fine, its just a dirty terminal in the variable resistor, nothing to really worry about, stuff like that happens.When it is a bright red is when its truly distorting, also with your other problem with the smelling a burning something, How long have you had the subs? Did you buy them brand new or used? How long have you been actually using the subs?
2000 Ford Focus ZX3
Mods:
Raceland Coilovers
Borla Exhaust
Aftermarket Header
System:
Sony CDX-GT66UPW
Pioneer 6x8's
System Upgrades :
Pioneer MVH-X560BT
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
