wiring New Kenwood hu
I have a new Kenwood kdcx497. I have hooked everything up except for my speaker wire because they are being amped but the hu will not turn on or anything. I don't know what to do anymore. Please help!
You must have wired the harness wrong.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
You probably have your 12V (red) hooked up incorrectly. You may need to run it to a fuse with a fuse tap. Google it, that's likely your issue and why your deck isn't firing up.
I am replacing a aftermarket Pioneer heaunit I hooked everything up the same exact way and nothing. I'm saying this because if I need the fuse tap why didn't I need it for the old one?
Pic of the harness? If it isn't turning on, either you goofed and mismatched a wire or your HU is DOA.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
You didn't wire it right or the head unit is bad
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Or you blew a fuse
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If you havent hooked up the speaker wiring on the harness and its a simple install then you literally have 4 connections that need to be made..
Red - ignition switched
Yellow - 12V(+)
Black - ground
Blue (maybe white striped) - remote
  • Who's Online   0 Members, 0 Anonymous, 1089 Guests (See full list)
