TheLeeStrikes Posted August 4, 2014 Report Posted August 4, 2014 So i have a Soundqubed HDS312 and im pushing maybe about 1k rms i have the sub in the trunk of course and i have the amp under one of my seats so its about 6 feet long and im using 14 gauge speaker wire for the sub do i need to get bigger size? and also i was wondering if this wire is any good http://www.knukonceptz.com/mobile-audio/speaker-wire/tca-speaker-wire/sp/tca-speaker-wire-10-gauge-tinned-cca/ also if i need to upgrade to bigger what are the reasons i need to just so i can learn it. what are the cons of having small wire vs having big wire.
alaskanzx5 Posted August 4, 2014 Report Posted August 4, 2014 I use 8guage for subs, reason why is less resistance, less power loss, and because I can. the longer the run the more resistance the more resistance the more power loss you have. Your subs see less and less of that power. A long run of small size could potentially get hot, melt and short out. Just move the amp to the trunk and run shorter speaker wire of 12 gauge or bigger. 4g from front to back 4 gauge ground to solid metal all paint cleaned off. look around here on the forum for threads about electrical, tons of great info on here. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Hugh G. Rection Posted August 4, 2014 Report Posted August 4, 2014 when im working with big power, i run big wire. in the past, ive used 4ga cable for my subs. Owner of BigAss Ports
alaskanzx5 Posted August 5, 2014 Report Posted August 5, 2014 With great amount of power comes great amounts of wire t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Tarball Posted August 5, 2014 Report Posted August 5, 2014 With great amount of power comes great amounts of wire and responsibility CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
