How important is the speaker wire size?
So i have a Soundqubed HDS312 and im pushing maybe about 1k rms i have the sub in the trunk of course and i have the amp under one of my seats so its about 6 feet long and im using 14 gauge speaker wire for the sub do i need to get bigger size? and also i was wondering if this wire is any good http://www.knukonceptz.com/mobile-audio/speaker-wire/tca-speaker-wire/sp/tca-speaker-wire-10-gauge-tinned-cca/
also if i need to upgrade to bigger what are the reasons i need to just so i can learn it. what are the cons of having small wire vs having big wire.
I use 8guage for subs, reason why is less resistance, less power loss, and because I can.
the longer the run the more resistance the more resistance the more power loss you have. Your subs see less and less of that power. A long run of small size could potentially get hot, melt and short out. Just move the amp to the trunk and run shorter speaker wire of 12 gauge or bigger. 4g from front to back 4 gauge ground to solid metal all paint cleaned off.
look around here on the forum for threads about electrical, tons of great info on here.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
With great amount of power comes great amounts of wire
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
and responsibility :P
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 414 Guests (See full list)
