Sounds like your abs is engaging or not releasing for some reason. Your rpms are higher , because your vehicle has to give more power to move if brakes are engaged.
Have you checked your brake pads? Check your brake cylinders also, one might be sticking. You could have a bad brake line (collapsed) not allowing brakes to release instantly as they should.
Could a warped rotor be a factor also?
None of the above will kick on ABS light
NEED to SCAN FOR CODES!!!!!!!!!
Aight. Going to autozone lol
Not sure if autozone can get into the ABS side of things
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
I'm pretty sure they have an ABS diagnostics
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
If is AWD check wheel speed sensor. Dodge is notorious for corrosive connection. Take connections off clean and use die electric grease.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
On my Buick, it was because my traction control and ABS computer bit the dust. Turned out that one of my battery cables came loose (stupid side post) and screwed up the computers
Scary as hell when driving and you go to stop and it does the ABS chatter while barely pressing the brake pedal, and enabling traction control when I barely hit the gas. it made every day feel like trying to stop and go on ice, at least until it finally threw a fault code and disabled ABS/TC entirely.
2016 Ford Focus SE
No build log yet
DC Audio 1.2K
2x DC Audio Level 2 10"
I should've checked this topic before I brought it to the dealership. Oh well. I'll find out what went down eventually. Tomorrow will be day 3 it's been there.
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Got my car back. Master analog brake cylinder was about to go out and the ABS module was having fits. So, yea. $955 repair. Paid $55. Thank the Lord for warranties. Only thing is the module...If it ever goes out again, nothing I can do at home because a fresh one has to be programmed to Dodge Caliber factory specs. Oh well
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
  • 1 month later...
  • Who's Online   0 Members, 0 Anonymous, 1232 Guests (See full list)
