http://sonicelectronix.com/item_12285_Pion...H-P5000DVD.html
ok so it has two pairs of outputs one front and one rear
now i was going to run 2 amps for my mids and highs (one for the front one for the rear) but this leaves no outputs for my sub amp
so my question is how do i make it so i can hook up the three amps (front rear and sub) and still have the fading from front to back on my mids highs setup?
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
all i can think of is split off the rear rca outputs and run those to your subs and set the amp to low pass and should work from there with a y adaptor
Edited by tacomabanga1986
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
run a Y off the front rca's and put the subs on the rear set. no fading for the front and rear channels but youll have a set for the subs....
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
bump in hopes for some help
use a set of "Y" cables some people call them splitters
----reference's----
meade916
well you can't control the sub from the head unit anyways so might as well either ONE get an 4 channel amp with a sum/sub out on it or TWO a crossover with front and rear input with front/rear/sub output.
im gonna check on number two
thanx for the help guys
i was hopin i wouldnt have to split the rca's but if thats wut i got to do thats wut i got to do
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
wut about this
http://www.sonicelectronix.com/item_8160_A...XS+-GRAY-.html#
id still have to split some i believe but i think it can make up the difference
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
get a crossover bro...done.
Follow my Tweet (Twitter)
