AQ2200 Clamp Test
Cj Kumz
Hey people I went on to clamp test my mates aq2200. Its powering a single hdc315 in a 4 cube box tuned to 37hz @ 1ohm on stock electrical..
Clamp meter read 11.5A
DMM read 50.3V
Box rise 4.4ohms
Watts rms 578
Question: Is the low wattage due to the stock electrical or is it the box rise?? The box rise seems to much to be normal lol.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Considering that amps specs are:
4 ohm power @ 12V @ 1% THD500x 1
Id say its due to the impedance rise, and even still rising to over 4 ohms, and still doing around rated power, that is if you at least had some way of measuring distortion or clipping to ensure that the output was clean.
Sounds right. Sundown SAZ-2000d of mine did 840 rising to 3.1 ohms on 10.4 volts. Was well in the clean power range too.
What frequency did you clamp?
unsure who you are asking Tfade, but I'll throw myself in.
41hz. Window open meter in the passenger kick on the USACi clamp.
How did you manage to calculate the wattage without knowing the phase angle between the AC current and AC voltage?
You know, the power factor?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I was asking the OP. If he's testing for amp output... it's usually best to clamp around tuning where rise is lowest. Or if he's clamping at his SPL peak it's nice to know how much (or little) power you need to achieve your score.
I was also asking about his speaker leads because he could have double the power and half the rise if he only clamped on speaker lead (if he has two).
DMM read 50.3V
Box rise 4.4ohms
VoltAmps 578
Question: Is the low VoltAmps due to the stock electrical or is it the box rise?? The box rise seems to much to be normal lol.
Fixed it for you. Feel better?
I clamped at 50Hz and clamped the single speaker positive going to the amp (sub parallel wired)
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   1 Member, 0 Anonymous, 773 Guests (See full list)
