deadbroke Posted August 10, 2014 Report Posted August 10, 2014 Would you wire a bulb before the tweeters ran in series or would you run one before each tweeter? Running active setup with re xxx tw 25 tweeters
audiofanaticz Posted August 10, 2014 Report Posted August 10, 2014 Depends, Are you doing 2 tweeters in 1 location ran in series from the same channel of the amplifier? If so doing 1 bulb prior to both tweeters in series is ideal. If your doing 2 tweeters in 1 location powered from a different channel than 1 bulb prior per tweeter.
audiofanaticz Posted August 10, 2014 Report Posted August 10, 2014 Worth mention that the bulb may steal some of the range from the tweeters, you could also use a 10-15uf capacitor inline or thermal breakers that open when they get hot, and reset when they cool off similar to something in the majority of component crossovers.
Soccerballzs Posted August 10, 2014 Report Posted August 10, 2014 A 1 amp fuse works also. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
deadbroke Posted August 10, 2014 Author Report Posted August 10, 2014 Well I already built the doors to hold 4 6.5s and 4 tweeters each. The tweeters are 4 ohm so I was thinking about running 2 in series to get me down to 2 ohm and wire the other two on another channel. Planning to get a 3sixty.3 as well. I'm open to ideas since I have yet to buy any amps yet but when I do I plan to buy rockford ones
White Lightning Posted August 11, 2014 Report Posted August 11, 2014 Running active setup with re xxx two 25 tweeters if you are running active, what's the need for anything between the amplifier and tweeters ??? Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
4bannger Posted August 11, 2014 Report Posted August 11, 2014 what is the purpose of a bulb or fuse between the amp and the tweeter?
audiofanaticz Posted August 11, 2014 Report Posted August 11, 2014 if you are running active, what's the need for anything between the amplifier and tweeters ???Id have to assume a fail safe in case he doesn't set the crossovers or gain properly would be my only guess. However depending how he is doing his processing and if he ever loses power to the processor and all settings are erased, and you forget all about that when you hook power back up and jump in your car, the light bulb could save you from blowing your tweeters. what is the purpose of a bulb or fuse between the amp and the tweeter? Essentially tweeter protection. As someone else said about using a fuse, you can however a light bulb is far better. In extreme cases the light bulb will handle power better and over time the filament in the bulb may start to glow which will raise the impedance resulting in less power sent to the tweeter keeping it safe where as a fuse would just blow and your tweeter is done working until you change your fuse again, the light bulb will not blow (unless your doing something way wrong. Also if your clipping your amplifier that light bulb will also take the grunt of that abuse as well. But you still must keep in mind that the light bulb could drastically alter your tweeters response.
deadbroke Posted August 11, 2014 Author Report Posted August 11, 2014 audiofanaticz got it right just in case more of a fail safe than anything. I have heard different things about bulbs but not much for them in series if I should add one before both tweeters, one before each, or two bulbs even, because I have seen some audio company soldering two bulbs together and selling it that way just wanted more clarification on it .
deadbroke Posted August 12, 2014 Author Report Posted August 12, 2014 Is no one familiar with series wiring with the bulbs?
