ToNasty Posted January 11, 2015 Report Posted January 11, 2015 id like to here this one day soon, was talking to tyler last night and he said he was impressed ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
islandpride684 Posted January 11, 2015 Report Posted January 11, 2015 Can some one do the picture thing for me im on mobile or ill do it later in pc http://i27.photobucket.com/albums/c180/whatisit2006/Malibu%20Project/20150111_121653_zpsj5kbds3n.jpg http://i27.photobucket.com/albums/c180/whatisit2006/Malibu%20Project/20150111_121622_zpskxhmyw0n.jpg Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
vetkilr01 Posted January 12, 2015 Report Posted January 12, 2015 Pretty good slacker. Do you have any port pics and rear deck as well? And owwwwww yeahhhhhhhhhh and a freakin video. hahahha says the guys that still hasn't posted a video of his malibu . im still not done with the rear deck still need some trim pieces but ill get some pictures today. Hahaha touche'
diegoclass2010 Posted February 17, 2015 Author Report Posted February 17, 2015 small update guys, just got back into working on the build again. stated to do some testing and tuning and wow do i need to put in alot of work... 20hz for shits and giggles
diegoclass2010 Posted February 17, 2015 Author Report Posted February 17, 2015 what i have been up too and found out * 2 volts rcas suck * pac lc1 dint work for me/ replaced with a jl audio cl-rlc much better, bumps up rca voltage 7.5v * replaced one bad rca cable *found out box rise is a bitch *alot of air/bass is going to the trunk *roof by windshield flexes alot * baffle doesnt like 20hz and flexes alot * finally able to tuned with a dd-1 *finally started to use the im-sg and its a beast! on a whole another level, stated to use it today it blew my mind *i have two peaks 26hz low peak at 33hz high peak *i tuned way to low (30 hertz) for some reason i kinda like the port *i have 3.65 cubic feet on the sealed side. not bad 1.80 per sub *wiring at 1 ohm sucks. the amp never see's under 2 ohms what i plan to do... * find a way to seal of the trunk with expandable foam by the rear deck *make new ports with different tuning *play with the polyfil in the seal side and verify with the im-sg to get biggest cubic feet. *if i were to burn up the subs recone with d2 to wire down to half ohm * maybe add fiberglass layers to the roof to try to reduce the flex * reinforce baffle im open to opinions and help guys.. wheres my loud trunk guys? i know you guys are out there
diegoclass2010 Posted February 17, 2015 Author Report Posted February 17, 2015 here's some motivation for you guys
zrkie Posted February 17, 2015 Report Posted February 17, 2015 Killer window for display in the boot! Don't like sharing your knowledge? Welll.. Don't come here and grab others then! - GTFO.
bigsausagepizza Posted February 17, 2015 Report Posted February 17, 2015 thanks guys .... minor updates... (nothing special layer after layer of fiberglass....) just keeping you guys posted What is that you have inlayed in the fiberglass? I haven't seen that before. 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass
KO4Life Posted February 17, 2015 Report Posted February 17, 2015 Tuned in, how many cuft is that box? Budget Banging On A Budget..... 99 Civic EX Coupe XS Power/SkyHigh Powered Build In The Making...
diegoclass2010 Posted February 17, 2015 Author Report Posted February 17, 2015 Killer window for display in the boot! thanks bro thanks guys .... minor updates... (nothing special layer after layer of fiberglass....) just keeping you guys posted What is that you have inlayed in the fiberglass? I haven't seen that before. its just pieces of 1/8 flat metal i cut up and add as ribs to give the enclosure strength... alot of people do it sometimes instead with wood Tuned in, how many cuft is that box? believe it or not im still barely finding out.. but roughly its about 15 cubic feet with the spare tire incluede
