BigManAC Posted August 18, 2014 Report Posted August 18, 2014 I got into a conversation with someone today and the convo steered toward car audio/electrical. He said he wanted to run his amp on a 14v system and asked me how to do it. I told him I didn't know but I could look it up. I know the going phrase is "if you have to ask how to run a 14v/16v system, you probably shouldn't do it", but I want to get some I do and get back to him. I know there are two ways of running a 14v system, a 16v alt with a step down, voltage reg and...isolator?. Not sure. The other, run the 16v alt on a different electrical run than the car electrical. On this would all negatives ground to the frame or no? Anything I'm missing? I would like to learn the basics for future reference in case anyone ask. As for myself, I'll stick with 12v haha. TIA 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
philrab Posted August 18, 2014 Report Posted August 18, 2014 Kinda in the same boat here. I don't see myself running 14V on my car, but I'm curious. Taking a shot in the dark (not giving advice, just curious what the Pro's respond with) I'd venture to say one method would be a dual alt setup, running independant wiring straight to the amps, that way the stock alt drives the stock electrics and the HO alt drives the audio. I don't see any major issue with grounding the HO alt and the amps to the frame same as everything else, but then again I am just spitballing here. In for the experts. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Kyblack76 Posted August 18, 2014 Report Posted August 18, 2014 You both are running a 14v alt SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Leo1103 Posted August 18, 2014 Report Posted August 18, 2014 Most reliable way I think would be to keep separate charging systems. For example have 2 or more alternators, 1 running the 12v side (car) and another running either the 14v or 16v side. But it will be different from car to car 2002 Honda CR-VAlpine 9887My BuildRebuilding... Second Skin Damp 4 DC XL 15's 2 DC 5ks Singer 320 amp 6 cap banksSky High wire 2 VM-1's OM-1 all under window line Team DC Audio Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.EDIT: Not in a JP kind of way. I thought I was going to die from all the jizz filling my ears.
Leo1103 Posted August 18, 2014 Report Posted August 18, 2014 also keep in mind a 14 volt system charges at 16.8 ish volts and a 16 volt system charges at 18+ volts 2002 Honda CR-VAlpine 9887My BuildRebuilding... Second Skin Damp 4 DC XL 15's 2 DC 5ks Singer 320 amp 6 cap banksSky High wire 2 VM-1's OM-1 all under window line Team DC Audio Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.EDIT: Not in a JP kind of way. I thought I was going to die from all the jizz filling my ears.
Kyblack76 Posted August 18, 2014 Report Posted August 18, 2014 Correct. Tell him he IS running a 14v alt. What he wants is 14v bats, which would require a 16v alt. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted August 18, 2014 Report Posted August 18, 2014 Correct. Tell him he IS running a 14v alt. What he wants is 14v bats, which would require a 16v alt. 12v systems charge at 14v. 14v at 16v. 16v at almost 19v.
Kyblack76 Posted August 18, 2014 Report Posted August 18, 2014 Step down on a 14v alt. That's a new one. Op, do you see what we are getting at??? Ps Real men do it on 12v Still waiting for my decal. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Jhunt94 Posted August 18, 2014 Report Posted August 18, 2014 Had to explain this to someone the other day. People don't realize that you already have a 14v system in your vehicle and adding 14v batteries will make it a 16v system and 16v batteries will make it an 18v system. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
TRON Posted August 18, 2014 Report Posted August 18, 2014 You have to be careful going to a 14v system, mainly because the vehicles electronics are built to go up to 14.4v or maybe a bit higher, depending on the vehicle. Your fuel pump won't 16v Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
