help! sub is poping
Sid420
It does it about every 20 seconds or so after I started the car. It looks like the sub goes in then pops out then 20 seconds later same thing in and pop out
When I turn my car on my subs will pop twice but I have the amp all the way down and the hu all the way down. I checked my rcas and everything but nothing seems to be different then my last system which is using the same wires and they never popped. Help please
Does the woofers pop when you change tracks on a CD or change sources on the unit? Usually it is caused by the amp turning on before the units line outs are activated. In your case, it pops every 20 seconds indicates a bad head unit ground/bad amplifier ground/bad rca/bad amp. If you unplug the amp RCA's and power the amp back up, does the woofers still pop? If so, get a DMM and test amp ground continuity if it is a good connection and your terminals and ground are solid to the point where you can't move it without tools then your ground is probably good. If the amp is getting 12.4v+ on the b+ & 12v+ on the remote then your wires are good. Probably a bad amp.
bad amp or head unit.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
