Is this an aftermarket exhaust? Any other mods? what octane of fuel do you run. Some amount of color change is normal but it can also be from a lean fuel mixture causing the bike to run hotter than normal.
I can't see my self ever riding with flip-flops...
When I am moving my leg is fine, it's only when I am stopped. I am seriously considering exhaust wrap, where can I get some? Is the stuff at auto zone fine?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
what octane fuel do you have in the US?
over here is either 95/98 or 100 octane..
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
na stock as far as i know. unless the previous owner changed it, but it looks exactly like stock.
I run the 93 octane in it. Or whatever happens to be the highest at whatever station i stop.
and no mods, again as far as I know.
Its a Vstar 650, if that makes a difference.
F150:
Stock :(
Processor: DSR1
it can also be caused by a rich mixture as well but usually that occurs further down the exhaust.
Do you know if anything else was done to the bike? An aftermarket exhaust requires a carb jet change or a new fuel map if fuel injected.
I don't think anything was done. I bought it with about 1300 miles on it. It was a lady who thought she would ride it but in 4 years put 1300 miles on it. As far as I know it is totally stock.
F150:
Stock :(
Processor: DSR1
just heat, its normal.
Hammerdown... 1%
I would take to a knowledgeable shop in your area and get your carbs rejetted you will probably notice a performance gain from doing so as well. Or just have them do it at your next scheduled maintainence. You could also just do nothing if it seems to run fine you could just leave it alone but that's not what I would do personally. Or if you are mechanically inclined you could probably find a write up on the vstar forum along with jet recommendations.
It has been like that since I bought it. I just finally decided to ask someone other than the place I bought it from about it. I took it in and had everything adjusted and fluid levels changed and so on. It is due for it's next maintenance in about 600 miles. I will have them make sure then. I have noticed no performance losses at all the whole time though. it still starts just fine (except on really cold days, gotta use the choke a bit then) and power hasn't dropped off any.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
