fufhubbin Posted September 2, 2014 Report Share Posted September 2, 2014 i have the orion hcca and the fs is 44 hz . the box i built is tuned at 34 hz and i was wondering what the subsoinc should be set at? is 44 hz for an fs pretty high? Alpine type Rs are like 28hz ORION HCCA 10.4 2000 watts RMS 4000 watts max hifonics brutus 2600 bxi Alpine IDA -305 Digital receiver 0 gauge power wire 250 amp fuse 800 watt BUTTKICKER BASS SHAKER Kicker zx-400 amp to power buttkicker Link to comment Share on other sites More sharing options...
hoit Posted September 2, 2014 Report Share Posted September 2, 2014 what size sub? 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
Kyblack76 Posted September 2, 2014 Report Share Posted September 2, 2014 what size sub? why would that matter? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
hoit Posted September 2, 2014 Report Share Posted September 2, 2014 a 10 like your sig says? i'd say 25-30...but this is kinda a personal opinion...anyone else? 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
GorillaFIngeRs Posted September 2, 2014 Report Share Posted September 2, 2014 I've heard its one octave lower than your tuning freq. It's not personal preference either, subsonic is gonna help you not tear apart your soft parts. I know some guys run without a SSF but they know what they are doing and they are tuned for it. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator Link to comment Share on other sites More sharing options...
Guest Posted September 2, 2014 Report Share Posted September 2, 2014 sub size nor Fs dictate the subsonic set point. Link to comment Share on other sites More sharing options...
hoit Posted September 2, 2014 Report Share Posted September 2, 2014 ...so...where should the op set the ssf at? (im just here to learn) 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt Link to comment Share on other sites More sharing options...
GorillaFIngeRs Posted September 2, 2014 Report Share Posted September 2, 2014 http://www.decibelcar.com/menuelectro/119-subsonic-adjust.html Half an octave below tuned freq.... Might have to read AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator Link to comment Share on other sites More sharing options...
Joe X Posted September 2, 2014 Report Share Posted September 2, 2014 Half an octave below tuning frequency, the subsonic filter won't prevent above tuning over excursion if it presents itself though. Link to comment Share on other sites More sharing options...
fufhubbin Posted September 3, 2014 Author Report Share Posted September 3, 2014 so divide port tuning by 4 ( get the answer then subtract that from the boxs port tuning so half an octave lower would be 34/4=8.5 34-8.5= SET SSF to 25.5HZ is this correct? ORION HCCA 10.4 2000 watts RMS 4000 watts max hifonics brutus 2600 bxi Alpine IDA -305 Digital receiver 0 gauge power wire 250 amp fuse 800 watt BUTTKICKER BASS SHAKER Kicker zx-400 amp to power buttkicker Link to comment Share on other sites More sharing options...
