4th order gurus needed
Well I've been fed so much different advice. I'll give you a rundown on my testing so far.
started with the port being 18 by 34 by 2 inches deep- played basically 44hz and that was it
was told that to move air to try tall and thin so went to 10 by 34 by 2 inches played a decent ammount but didn't move air I wanted
shrunk that down to 8 by 34 by 2 inches did a lot better but couldn't play lows like I wanted
was told to try to lengthen port so the 8 by 34 by 12. didnt do a damn bit of difference that the 2 inch deep one
And the one you see is 14 by 16 by 4 inches deep. Like I said it'll play almost anything I want its just that its missing that air movement that I need
What sencheezy said about testing times a milion. Believe it or not in my truck ive always found smaller loading chamber port areas to improve lows. I was going to suggest trying smaller port area until I saw that picture of your port...looks like around 250-280sqin or so yeah?
Team NorthWestSPL
Try this, remove the round overs, just do that, and see what happens. After that, try one window up, one window closed, then switch sides, then roll both down, see how your vehicle reacts to those changes. My round over hurt my low end, so I removed that bish lol.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
^^^ this guy its all testing..
Port Area: 38'' Tall, 23.5'''Wide 4" Thick
And here, you can see, by changing the orientation of windows and doors, how your frequency response can change.
6 15" SSA Evils
18 XS Power D3400s
Alright so doing a little more testing here in the near future. ( I have 3 exams next week so my weekend is in the library)
I wanna know what has worked for you guys port wise. I know that the person who origianlly helped me with the design (berger) said that if I wanted to play low and doors open to do a tall skinny port. ( I have 34 inches of height to work with)
And when I got back from bergers I did the port with someone who has a 4th and he said square is better for him, So we went with square.
What has worked for you guys?
  • Who's Online   0 Members, 0 Anonymous, 5052 Guests (See full list)
