memphissound3180 Posted September 24, 2014 Author Report Posted September 24, 2014 Thanks and I will before long just getting everything ready for now ordering the second AQ Friday then break in time
pioneerforlife Posted September 24, 2014 Report Posted September 24, 2014 That wall will do some work. and like I said the rubicon amps are awesome. I have ran one and have had buddies run them. I run the tarantula 3K's and those are great as well. Running them at quarter ohm with no problems. also I would tune between 32-34. if you wanna play lows and highs fairly well then tune to 34. if you don't care about highs as much, 32. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
MaxVolume Posted September 24, 2014 Report Posted September 24, 2014 the difference between 32 and 34 hz seems pretty small when it's going to be designed on a computer, built by hands, and loaded into a car environment. build it at 30/32/75 hz whatever and if you want it lower/higher, rebuild port and change it +/- 5 hz. I have a few designs for my next build and all incorporate interchangeable ports for this very reason. I really want to see how this turns out, and if after a while he wants more out of it, he can always upgrade amps later
memphissound3180 Posted September 24, 2014 Author Report Posted September 24, 2014 I'm hoping it will bc it's in a probe so small car + wall should = breaking stuff but should I strap them at 2 ohms so each amp is seeing 4 ohms or at 1 so each is seeing .5? I've heard you can run them at .5 but they get pretty hot after awhile
pioneerforlife Posted September 24, 2014 Report Posted September 24, 2014 If you strap at 2 each amp would see 1 ohm. I would try that to be safe at first. then maybe drop it lower after a while. but you can run them at .5 but with good cooling (fans) and good electrical. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
SlamminBeats Posted September 24, 2014 Report Posted September 24, 2014 running sound stream amps at 2 ohms, not disappointing?... sorry no offense OP anyways if you want to play down to 30 hz then id suggest tuning to around 35-38hz. I cant really say for sure but that range would be a good start. I had my hdcs tuned at 42 lol they dropped off at 34 hz. I then cut my port big time and dropped tuning and they could play down to 28hz. if i had to guess i would say i was tuned at upper 30s.
memphissound3180 Posted September 24, 2014 Author Report Posted September 24, 2014 I have one AQ 18 in a 6 cubic foot box right now tuned to 30-31 and it starts to drop off around 24-25 but I don't need to go that low
memphissound3180 Posted September 25, 2014 Author Report Posted September 25, 2014 If I get two of the AQs how much port are should I have? 120"? Bc I have a design for both tuned to 30hz in about 13 cubic foot
Karkov Posted September 25, 2014 Report Posted September 25, 2014 strapped at 2 so each seeing 1 ohm. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
memphissound3180 Posted September 25, 2014 Author Report Posted September 25, 2014 That's correct I will be strapping them at 2 ohms for now and later I'll strap them lower when I get better electrical
