youngbass98 Posted September 26, 2014 Report Posted September 26, 2014 I am about to wall my Monte carlo with 2 18s and was wondering what you guys use to secure your box to the car I was going to use L brackets but do I need anything else? 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
audiofanaticz Posted September 26, 2014 Report Posted September 26, 2014 I mean if your going to use L brackets you might as well use velcro... Bolts, big stinking bolts through the body of the vehicle.
audiofanaticz Posted September 26, 2014 Report Posted September 26, 2014 PS: make sure you watch where your drilling your holes so you dont drill into your gas tank!
juan777 Posted September 26, 2014 Report Posted September 26, 2014 Check my thread: http://www.stevemeadedesigns.com/board/topic/190642-wall-building-101-pics-etc/ The L@zy Hoe 2005 Chevy Tahoe 2,500 Watts of Highs/Mids 4 10 midrange 4 6.5 midwoofers 4 Tweeters 6 Supertweeters 2 Lithium 80AH Batteries 24K Watts 4 Custom 18s Quad alt setup Rebuilt 250amp and 3 370s Interior work by Lone Star Auto Works The Build Log Like Loud Bass? Click Here! On 12/5/2014 at 8:06 PM, juan777 said: See yall there, I'll be the drunk Mexican with aviators on. On 12/6/2014 at 10:32 PM, boom50cal said: I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Kyblack76 Posted September 26, 2014 Report Posted September 26, 2014 Pl glued OSB to the roof, then 2 sheets of 3/4" birch to that with PL glue and screws. Same on the floor. Sides (walls) to that. If the top and floor are that secure, the sides go in, then brace those. Done..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
philrab Posted September 26, 2014 Report Posted September 26, 2014 Most walls I've see wind up being at least a couple hundred pounds of wood, subs, wire, amps, ect. You do not want that shit to smack you in the back of the some if you get in a fender bender. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Cardboardcat15 Posted September 26, 2014 Report Posted September 26, 2014 Bolts, bolts, and more bolts. If you can, find stock bolt areas like seatbelt bolts and places like that and use those. For my wall I used the OEM bottom seatbelt bolt holes through the body of the car. Otherwise, through the body of the car. map em out and make sure you know where youre drilling. The rear deck can also help, if your box is flush up against it. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
youngbass98 Posted September 27, 2014 Author Report Posted September 27, 2014 thanks for all of the replys, found some factory bolt holes under the seat, so I'm going to use L brackets and the bolts. 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
philrab Posted September 27, 2014 Report Posted September 27, 2014 thanks for all of the replys, found some factory bolt holes under the seat, so I'm going to use L brackets and the bolts. L brackets? Guess you didn't pay attention to the advice you asked for. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
evermaxx Posted September 27, 2014 Report Posted September 27, 2014 Lemme know how those L brackets work when someone brake checks you and you're part of your wall. In for pics. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
