In home car audio question.
Working on a small project. All of it is simple enough. My question is: is there a point to using a battery in a situation like this?
My PSU SLi rated at 60a on the 12v side. But its exactly 12.03 V and we all know car batteries charge at 14.4V..
So either a) charge a small 12v battery at 12v... which isnt good. Or find a 9-10V battery but then a large part of using a battery is to be able power the rig for a short time anyway away from a plug.
And a 10V batt isnt gonna do too much good without the DC supply. As 10v and below isnt really amplifier friendly.
If that makes any sense atall..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Kind of confused at what it is that you even want to power?
Amplifier. Source unit. Many ppl do this at home its not complicated. I would simply like to make it portable. Which means using a battery. And you cant charge a regular car battery say a D975 or w.e with a 12.03V source.
Setup:
Xs D3400/ Xs XP3000
No, you can not. They are split by diodes usually which means technically they are all one big rail just divided up for "convenience".
Modify the +12V sense wire of the PSU and then you can crank it up to 13v+. Some go higher, some dont.
Hammerdown... 1%
