Plexi wall
stipek
Just an idea....has anyone done a wall with the baffle being a big sheet of polycarbonate. Boxes have been seen with the sides done in plexi to look inside but not a baffle.
Questions arising would it be structurally sound. Mounting the subs might be tricky unless you had someone machine the mounting holed and cut to size.
Could also use clear tubing for bracing. Drill and tap maybe.
I have zero experience with walls, so is this just crazy or what?
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
Sure its possible, but extremely expensive to do.
Also polycarbonate and plexi are not the same thing, FYI. Plexi = acrylic, polycarbonate = lexan. They are both clear plastics, but they each have their own advantages and disadvantages.
Builds:
It would be expensive as Fuck. A 3"x48"x48" sheet of plexiglass is $4k
Used to have a loud truck
Been done many many times.
First I remember (even though it's not a sub box, more of a fourth order loading wall for his trunk box) was Fishman's Corolla in 1991.
http://www.mobilesoundscience.com/showthread.php/771-Dave-quot-Fishman-quot-Rivera-1988-Toyata-Corolla-1992-CA-amp-E
Google image search for plexiglass sub box or acrylic enclosure. There are many and I'm sure if you click through they'll tell you how it's done best.
Static drops are my bag.
Yeah thats pretty crazy.
http://www.stevemeadedesigns.com/board/topic/161992-clear-box/page-2
i know its not a wall, but sort of the same concept
Basically what i was thinking of.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Main reason other than being badass is to display some art work inside the enclosure. Plan for back side is to do standard fiberglass displaying amps but could hide amps underneath and put sheet on the back instead i guess.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   0 Members, 0 Anonymous, 8279 Guests (See full list)
