Totalnoob Posted October 18, 2014 Report Posted October 18, 2014 Hey i have a question on wiring an amplifier to a rear battery. If my amplifier has fuses on it do i still need to put a fuse on the power wire to my second battery? also can you guys double check to see if i have my wiring down before i burn down my car. ok so what i am planning on doing is run a power wire from my front battery with a fuse 300A fuse near that battery then connect that wire to the rear battery positive. and im not sure about a rear fuse for the amp.... My amp has 2 100a fuses in it. i made visual down below. all wiring will be done in 1/0. Front Batt+--->Fuse-->Rear Batt+----->200A Fuse???---->Amplifier+ Now for the ground on the rear battery do i need to ground it to the chassis or no grounds at all just connect my amps to them. Rear Batt Neg--->amp Neg or Ground in rear somewhere inside trunk area---->Rear Batt Neg----->amp Neg
islandpride684 Posted October 18, 2014 Report Posted October 18, 2014 Fuse the front battery and then before the rear battery...either run another run for the ground from the front battery or find a good ground in the back...sky high wire? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
bcbrassard Posted October 18, 2014 Report Posted October 18, 2014 Just think of the wire between the batteries as fire starters. So you want to fuse before and after any secondary batteries to be safe unless it is a very short run to amp. Heres some pics of what i did to give you a example. My electrical consists of 200+ Singer alt, to batts under the hood and 2 in the trunk. So lots of OFC wiring and fuses. So much i had to buy one of these for crimping.
alaskanzx5 Posted October 18, 2014 Report Posted October 18, 2014 Listen to him. Bcbrassard, next time I'm coming into anchorage u need to get ahold of you. I need some wires crimped. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
bcbrassard Posted October 18, 2014 Report Posted October 18, 2014 Listen to him. Bcbrassard, next time I'm coming into anchorage u need to get ahold of you. I need some wires crimped. Sounds Good!
Totalnoob Posted October 18, 2014 Author Report Posted October 18, 2014 Yes it is sky high 1/0 wire. wow thanks guys for the pics and info, so i will fuse both sides of the power wire run. One near the front with a 300A fuse and the right before the second battery i will put another 300A fuse. and then the run from the second battery to the amplifier dont use a fuse because my amp is fused already. Or should i put a fuse for extra safety or will that just be wasting money? so how does this look now. Front batt+-->300A----------------------------------->300A--->Rear batt+---->amplifier+ or Front batt+-->300A----------------------------------->300A--->Rear batt+----200A???????-->amplifier+ and for the ground i will find a nice grounding spot in the rear somewhere
TRON Posted October 18, 2014 Report Posted October 18, 2014 The more, the merrier. It's better to have it and not need it, then to need it and not have it. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Totalnoob Posted October 21, 2014 Author Report Posted October 21, 2014 ok good. now lets say in a few months i decide i want to add a second rear battery. Would i have to ground that battery as well or can i just connect it to the other rear battery in the back.
Totalnoob Posted October 21, 2014 Author Report Posted October 21, 2014 Dang i just did some research and need to know if this is true. ok so, is it true you cant mix 2 different size batteries in parallel? like for example if i have a xs power d3100 up front for my starter battery and i am putting an xs power xp950(possibly 2) in the rear would one battery cause the other to drain faster or something? would i need what is called an isolator if i do this set up? help please
MrSkippyJ Posted October 21, 2014 Report Posted October 21, 2014 mixing sizes is fine, mixing different types causes draining issues. no need for an isolator at all. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
