Amp doesn't power sub.
Use an oscope and test speaker outs to see if your amp is putting a signal out. Try a different sub. Try a different amp.
Just use a volt meter.. get a cheap one from harbor freight for free with coupon or like 3 bux if not.
Set it ac volts at its lowest setting which I think on those is 200. Red wire to positive speaker terminal. Black wire to neg speaker terminal.
Play music or tones. You should get a reading. A tone is better because itll be a constant value while the tone is playing.
If not, it could be the signal. Make sure the rcas are plugged in. Your gain could be way low if you have a weak signal. So for the purpose of testing only, if your gain happens to be set real low right now turn it up to like half to test the voltage. Also make sure the lpf is set all the way up. Hpf all the way down. Ssf off or all the way up. For testing if the amp is putting out only. Reset everything to normal afterwatds.
Double check all connections.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
