Highs amp goes into protect when bass hits
Eye opener
OK, your lights dim because your system pulls more amps then your alt can produce. Therefore I bet your battery voltage is really low. you need either more batteries to supply your demand or high output alt and another battery. Either way I bet if you put it on the charger over night your problem will go away for a little bit until your system takes more current then your alternator can produce.
How did they set your gains? ?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
So
2/0 guage power to the sub amp
What size ground? Is it to care metal no paint? Where is it grounded to (sheet metal , seat bolt, frame/chassis)?
4ch amp has 4guage power
What size neg? Not grounded with the sub amp? Where is it grounded? No paint bare metal?
Upgrade that 8guahe ground coming from your battery neg, needs to be the same size as the wire going to your sub amp. Do the big 3, alt to battery positive, alt case to ground, battery ground to chassis. Alt case ground to battery neg would be good to.
Yes an ho alt would help drastically. Imo if you can manage a 200amp alt or bigger with a battery or 2 in back.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 859 Guests (See full list)
