charging agms?
dont charge them above 14.4
a good charger will stay around 13.5.. thats all you need to top them off.... they will float around 13.1
Ctek 7002 charges my xs d3400 and 2 xs d3100s check Amazon or sonicelectronix
Or it's little bastard step brother found locally if you have a menards.
http://www.menards.com/main/tools-hardware/automotive/batteries-chargers-jumpers/3500ma-battery-charger/p-1798465-c-14195.htm
I have that charger^ works well.
Played 40$ I think
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
in for knowledge...I would think youre fine until you start to drop in to the 11 and under.?
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Every time i buy an XS batt, they include a little slip that says nothing over 14.6 for charging. So I don't exceed that.
Also, Schumacher is terrible, they charge at stupid high voltages. I found this out the hard way.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
one thing i was told is even though they can handle 14.6 volts don't charge them that high. it will shorten the batteries life. its best to be at 13.8 for longer battery life
for people who use voltage regulators is to set it at 14.4-14.6 during comps and bring it back down to 13.8 for daily
i would say it goes the same if you keep them on the charger. one thing i did notice is. if you are going to let the batteries sit its better to keep the charger on them than to charge them weekly. i have the schumacher and the voltage never goes over 13.5.. its when you disconnect it and connect it again when it does that. somehow it thinks it a low battery and tries to charge a fully charged battery.
  • Who's Online   1 Member, 0 Anonymous, 1270 Guests (See full list)
