Hey guys!
Just signed up here and have a few questions.. Just bought a 95 s10 blazer with a brand new set of 26'' rims that came with it.. There really nice and was told they would slide right on and that just isn't happening.. Did a little research and a few guys said they used 2'' bodylifts.. Was wondering if I did a suspension lift and no body lift (Cause I think body lift serves no purpose) would this work for these? Or would I need to do both? Thx!
Chris
Yes, it can work
Friend used spring locks from PepBoys and he had no problems.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
dont use spring locks they can vibrate out and cause problems but yes a suspension, block, or body lift would work if i where u i would look into a leveling kit just makes the truck look so much better
Build Log
1996 chevy suburban
2 zv4 15
kenwood excelon mids and tweeters
kenwood excelon deck
mevhman 370
3 batts all different
mechman avmb II
2 inch squat
33 inch muds
straight pipes
kixker zx series 4ch
sundown amps
memphis 0 gauge
soon to be fu audio c pillar wall
If all you need to change is the clearance between hub and body, either lift type will work.
Static drops are my bag.
If done CORRECTLY and you don't drive like a dumbass, they will last. He's had them on there for over 2 years. Never had a problem. Daily drove it for about a year and half too.
Team Subsonic Lows
A body lift would be the cheapest/easiest I would think bro, its been almost a decade since I needed any kind of lift but I remember body lifts were cheaper, at that time anyway. I say body lift because all you need is for the wheels to clear the body, so a 4" body lift probably will be enough, but I know NOTHING about these types of blazers so do a lil research online about how much clearance you'll need and get a body lift accordingly, all the body lift does is raise the body from the fame so it's perfect for clearance especially if you're not off roading.
Oh and X2 on pics bro! I wanna see the wheels and truck!
I would just buy a leveling kit, install it and call it a day. Pretty cheap to buy relatively simple or cheap to install
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
that's the easiest way and the cheapest, plus leveling kits make a truck look bad ass. I hate the dumb ass nose dive stance
Build Log
1996 chevy suburban
2 zv4 15
mevhman 370
mechman avmb II
2 inch squat
33 inch muds
straight pipes
sundown amps
memphis 0 gauge
  • Who's Online   0 Members, 0 Anonymous, 1667 Guests (See full list)
