Bracing with angle iron (thick...not the flimsy stuff)
magillaru
If I'm going to add bracing with thick angle iron (not that crap you can bend by blowing on it), I need to use carriage bolts, correct?
Singer Alternators
Team Asshole
#anothershittysingerbuild
What do you mean by thick? And what size angle? Like 2x2x3/8?
Ehh, not sure yet....basically something that's going to provide good structural support.....something thicker than the stuff that you can bend with your hands.
Singer Alternators
Team Asshole
i used LAG bolts
Cool, thanks.
I was originally going to cut some wood pieces to lay along the edges but I think I'll feel better with some steel in there! :twirl:
Singer Alternators
Team Asshole
The sides and rear baffle shouldn't be a problem but the port walls and front baffles (each sub has it's own baffle) are my main concerns.....
I'll post a couple pictures later so you can see what I'm talking about.....to start, I'm planning on using a kreg jig (mostly for initial glue setting) but I want to make sure everything is solid....
I'll also be applying some tiger hair to all the internal joints (to make sure no air escapes and because why not).
Singer Alternators
Team Asshole
The port wall contact/joining points are top, bottom and front (against the baffle).
It shouldn't be a problem but I want to make every aspect of this box as strong as possible.
61369FF4-051E-4E82-A194-6A73653C1DC5_zps
Here's a shot with the port away from the baffle just to show where it's joining:
B7CCD4A3-9075-47CB-9265-73EB2A404410_zps
Singer Alternators
Team Asshole
I think you will be fine without the angle iron. Especially if you are using kitty hair. The angle iron will be overkill.
BUT..............
Overkill never hurt anyone. LAG bolts should work just fine for the angle iron, if you still decide to use them.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
As far as using the kreg jig, do you think I should fasten a few into the front baffle or just the top and bottom pieces? I also don't want to add too many screws and weaken the integrity of the wood.....
EDIT: sorry for so many questions.....this is my first time building an enclosure :shrug:
Singer Alternators
Team Asshole
  • Who's Online   1 Member, 0 Anonymous, 5316 Guests (See full list)
