i have a chyrsler 300 and usually have one side of backseat down but when back seat is up the the carpeted board peice makes the worse sound and the actual deck lid is sound deadened... I have the space where theres supposed to be a factory woofer and the board area has small grill holes so my question is if i were too put a port there would my system sound a little louder when seat is up with the extra air flow and with the small grill holes gone and a port there would that help with the rattle/vibration of the carpeted board?!?
Thanks
14 Chrysler 300S AWD On AIR!!!
I'm curious for answers as well. everytime someone wants to vent threw rear deck lid it's a 50/50 yes and no.
getting more sound into the cabin..but cancellation issues occur. (so I've heard)
but i had bad deck rattle my self.
i built a brace. drilled the base into the trunk made two 18x4 "walls" and then drilled the deck lid into the walls. no more flex..no more rattle
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
I like the idea of bracing it. This is what i did to try to reduce rattles.
Now The rattles and flex moved to the roof. So i guess thats the next step. Nothing like chasing the rattles.
The rattle your getting is the trim/carpet hitting up against the deck lid would be my guess.
Get some closed cell foam and put it on top of the deadener. Should help.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
fawqing clean build BC!
i have the same if not more deadner just like that. except i have 3 layers on the top of the lid 2 on the bottom...still made a ugly noise.
instead of spending another $100+ on deadner i used some left over mdf and 2x4 worked as i thought it would. was a nice place to put led lights in as well.
the trim pieces are a pain... like Alaskan said sniff em out. go to wally world buy some mattress egg carton looking foam go full Tilt while sitting in your rear seats. fill the gaps and move on. 20mins or so you'll fix the issue.
I'm gonna give you two tips tho.
1, be sure to play all sorts different frequencies, what rattles at 40hz won't rattle at 25hz and what rattles at 32hz won't at 55hz.
2, rattles never stop..every day week or month you will hear a new one.
stock up on weather stripping and cheap foam.
i have prolly 30hours of just stopping rattles in my car. might seem dumb...but when you give a demo and someone says "wow it's so clean..there's no rattle" it's worth it!
i have at least $80 bucks worth of weather stripping threwout my car.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
I'm ordering some closed cell foam myself for my rear deck. I have alot of sound deadner on it but it still makes noise.
I hear man, first you stop the metal rattles, then the plastic from hitting the metal rattles then its the plastic on plastic rattles. Will IT Ever End! lol
yea i dont have any metal rattle just the carpeted board when seats are up but i also wanted it too be louder when i have to have the seats up.... i was thinking about putting one these ports through the carpeted area where the factory woofer would be too hopefully make it a bit louder when seats up
it's not going to work.. the port will actually mess with he tuning and will fuck it up.. you just dont make a hole and hope it will sound louder.. you actually have to redesign the enclouser.. the best thing to do is building a bandpass box through the rear deck
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
