The box is being some sort of a horn style. The blue lines shows the walls in the box. The raised part is the floor of the "port" and brace for bottom and top part. Its been milled out in one piece. 4pcs total.
Bottom finnish, top will be identical.
Removed panels and carpet in the Jeep, and... got rust? Being some welding before sound deadner then.
That cone area though.
Lane AKA HeroKight
'96 Jeep Cherokee Classic 4x4
R.I.P. Molliboo
$200 for new tires, on a jeep!? Is she stealing them or building them with a heat gun and rubber bands?
You hear that????
That's a category 5 shit storm coming
n8: hey you doing today. What's it like being a bitch? you can pm me if you'd like to explain why you arent one. Just like you did for your vs threads.
^^^Rules. Follow them.^^^
Not that much actually, would have been more with 4x 18s.. but it will move some air anyway I hope :lol:
Small update. A friend of mine is welding the rust for me now, since he owed me a job..
All the plates to the box is finnish. Need to mill holes in the baffles and mount everything. Hope its being ok :)
Sick build so far! Watch out for those roof braces that go across, those things need packed with foam or something before you deaden the roof. I had to pull a bunch of dedener off to get to then later on because they separated from the roof skin lol. Everything about these jeeps is great expect for how flimsy all the metal is haha!
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
Thanks guys! Yes the roof will need some good bracing.. it will be a gap about 5-6" from top of the box, to the roof that needs to be filled with foam, wood or something. Also wounder about welding some angle iron from the floor to the roof for support, and brace for sidewalls of the box. maybe :)
Some more progress. Baffles is almost finish. Needs to be laminated and some paint. Then mount everything, and hope it fits in the Jeep :P
Some more progress. Mounted t-nuts in the baffles. Baffles and inner walls glued and screwed together. Started some painting.. Next is to glue everything to the bottom, mount outer walls. The open space inside the inner walls will be filled with foam, glue on the top and finish the painting. etc etc B)
  • Who's Online   1 Member, 0 Anonymous, 1484 Guests (See full list)
