What I'd do differently next time!
This is a thread you can use to post your "oh oops" and the things you'd do differently the next time around.
Let people know what canyons or lessons you learned so we can avoid the same mistakes.
Have fun...and keep it fun.
HU: Pioneer DMH-Z5350BT
Mids & Highs: ML280.3, ML700.3, ML1800.3 Mille Legend Series 3 way
Lows: x3 JL Audio 12TW3 powered by JL Audio RD1500/1
Cable: x2 Skyhigh 0 Gage OFC kits. Skyhigh 8 gage & 16 gage OFC speaker cable
Sound Deadener: 121 sq feet of Skyhigh 120mil
DSP: AudioControl DM 810
Project Build Log
Click here: 2001 Jeep Grand Cherokee SQ Build to see the build progress.
1. Make sure that you will be able to fit the box into the trunk before it is totally assembled. Made that mistake once. Got it in there, but had to remove a lot of stuff from inside the car.
2. When you are first learning how to solder large gauge terminals, make sure you are using electricians solder and not plumbers solder. Those were fun times. LOL
3. Always check twice and make sure that you are rounding over the correct edge of the panel. Wasted a couple pieces of wood that way.
4. If you have doubts about whether or not you have enough airspace. You don't have enough. Leave it at that.
5. If you are helping a friend, check and make sure that they hook up positive and negative polarities correctly on their amp before you through the fuse in. That one almost ended badly.
6. Do not set gains by ear. Use an oscope or a DD-1.
That's a start. I am pretty sure that there is already a thread about this too by the way.
Just use 0 gauge the first freaking time.
Ran 8 gauge for a little mono sub amp, swore I was going to leave well enough alone.
Decided I wanted a four channel, yanked out the 8 gauge, ran a 4 gauge to a fused distribution block to power the mono amp and 4 channel. Swore that was it.
Now, I want more power on the sub stage. Going to have to run the 4 gauge straight to the amp IF it'll reach, and run a 0 gauge (at least one) back to the hatch for the spare battery and sub amp.
Run a damned 0 gauge to begin with and be done with it. SMDH, think I would've learned by now not to think it'll ever be enough.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
never use cinchcable from homeaudio in your car
What is cinchcable?
Build Thread
What is cinchcable?
lol...i think he meant sync cable
Ah. That autocorrect is a bastard.
Build Thread
  • Who's Online   1 Member, 0 Anonymous, 642 Guests (See full list)
